| Home > Help Needed / General Tech Chat > fitting cam in 998 engine in situ | |||||||
3rd Mar, 2011 at 05:22:00pm
I'm in the middle of a 998t conversion. I have a NA MG cam to fit with vernier gear. I don't want to take the engine out to change the cam. I know i have to pull the followers first or loose them forever, then off with the old timing gear, old cam out and new cam in? timed to 108 degrees on number one. I cant remember if there is a removable section on the oil pump end?? or am i thinking of the spider drive?? On 7th Nov, 2011 apbellamy said:
3rd Mar, 2011 at 05:43:35pm
I dont know how you will be able to hold the followers clear of the cam to allow it to be withdrawn, but I,m sure if it can be done someone on here will tell us.
3rd Mar, 2011 at 05:59:34pm
998 has a tappet cover no?
3rd Mar, 2011 at 06:07:58pm
Ah, I see - its so long since I worked on anything other than 1275,s I forgot that some engines have the old (usually leaky) side covers) |
3rd Mar, 2011 at 06:19:43pm
As long as you have ab A+ with slot drive then it will work as you say. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 85 Posts Member #: 3600 Advanced Member Gateshead |
3rd Mar, 2011 at 07:12:55pm
I seem to recall reading in one of my reference books that the works team used to cut out the inner wing to enable this very process |
