Home > For Sale > JR Cone Filter & External Wastegate & HS4 Carb
dan
Member #: 93
Got some bit and pieces that will probably go on ebay this weekend if no-one is interested
first up is a JR Filter, see link below (doesn't inlcude silicon pipe)
http://www.k-tecracing.com/show_product.asp?id=14
dia 140mm tapering to dia 90mm over 195mm length
dia 65mm filter entry complete with turned alloy dia 65mm to dia 60mm adaptor
all brand new with the filter in manufacturers packaging etc
will accept ?45 inc p&p to within UK
next up is a brand new 35mm external wastegate, comes with 3 spring rates which i think were 4 psi, 7psi, and 14 psi, 3 spare diaphragms, 3 weldable plates, connector ports, basically everything you need to fit, plus instructions
will accept ?100 inc p&p to within UK
also got a HS4 carb, thats in really good condition, came on a turbo inlet I bought recently, fitted with an ADH needle I think
will accept ?25 inc p&p to within UK
can email pics for any of the above, pm for info
cheers
Zeemax Power
Member #: 393
Oulton Park
filters a dog don't mind telling you
http://www.Zeemax.com
what is that supposed to mean?
dan
Member #: 93
dunno
zeemax??
No nor me. Got a JR filter on one of my cars. As far as I can tell it is the same construction as a K&N or Green filter, only difference is the colour!!
dan
Member #: 93
yep i used to run this exact filter from k-tec on my 5 turbo a few years back, couldn't fault it all, hence getting this one
only reason selling is that i am going to try and fit in an airbox in the bulkhead so don't need this cone filter
