| Home > Wanted > Solid jet holder. | |||||||
![]() 489 Posts Member #: 9159 Senior Member Devon |
4th Mar, 2011 at 10:03:08pm
Anyone willing to make me one please?
5th Mar, 2011 at 08:36:12am
If any one will make one, Ill have one as I cant be arsed myself, due to poor eyesight doing fiddly bits like this. |
10th Mar, 2011 at 07:34:13pm
anyone?? really need one so i can start with my carb rebuild... |
10th Mar, 2011 at 10:54:14pm
there is a how to on here some where, bit of sheet ally, drill, a file and an hours hard work and bobs ur uncle!! Yes i moved to the darkside |
11th Mar, 2011 at 02:21:46am
Not alloy if you need to use E10 fuel -the methanol has a bad effect on it.
11th Mar, 2011 at 01:46:59pm
I used steel on mine. Just took the old one apart and used it to make a template, a hack saw, file and a drill a hole or two and you will knock one up. I run a supercharger and I don't care the TB is on the wrong side.
11th Mar, 2011 at 05:21:43pm
OK, you have convinced me.
12th Mar, 2011 at 06:18:58pm
ahh ok then, i'll have a go at it! :cool: |
