Home > Help Needed / General Tech Chat > Urgent help. I\'m ubder the car
Alex1340
Member #: 111
Loughborough
Hi guys. I'm current laying face up under the mini. How tight should the joint from the rod selector tothe gear box be? Should the roll pins grip the outside collor or should there be movement?
there should be movement, the sellock pin holds fast on the outside of the of the link boss and runs free ish in the middle
Alex1340
Member #: 111
Loughborough
<a href="http://s19.photobucket.com/albums/b190/alex1380/?action=view¤t=7069571e.mp4" target="_blank"><img src="http://i19.photobucket.com/albums/b190/alex1380/7069571e.mp4" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
george91
Member #: 8932
all looks fine to me, i took mine off the other day and there was some movement as benross said.
Alex1340
Member #: 111
Loughborough
Mine seems to be the other way round. Loose on the outside boss and tight on the in. Roll pins need replacing.
I'm having trouble getting reverse and I'm wondering if this is the cause.
Alex1340
Member #: 111
Loughborough
Found the problem the white plastic ball is no long on the gear leaver.
graemec
Member #: 1424
Carnforth, Lancs
KAD quickshift with lift up collar for reverse by any chance?
Alex1340
Member #: 111
Loughborough
yes............ this a comman problem?
graemec
Member #: 1424
Carnforth, Lancs
KAD say not, but I had the issue and I have heard of others.
In my opinion the grooves for the circlips are not cut deep enough so once the stick is chrome plated the circlips don't sit into the grooves properly an move too easily.
To be fair I returned mine to KAD and they sorted it and returned the stick.
PaulH
Member #: 2340
Dublin Ireland
This is q big probablem on the KAD quick shifts I have had this problem happen on 08, and 09 guick shift then modified the design on last years batch which seems to have solved the probablem
On 17th Feb, 2009 Rob H said:
Alex1340
Member #: 111
Loughborough
Arrr this explains why my mate at KAD said just send it back and they'll send out a replacement. Hopfuly it will all get shorted this week. Mot in a few weeks, going in gear I think would be an advantage.
Alex1340
Member #: 111
Loughborough
Got to say, sent my quickshift back on monday, they got it tuesday, new one arrived with me this morning can't fault them.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Every time I look at this thread I think someone is trapped under their car!
On 7th Nov, 2008 Nic said:
naeJ
m
Yeh, isn't your missus, your mother, or your neighbours getting worried that there are a pair of legs sticking out from under a Mini, without movement, for 4 days?
