Home > Help Needed / General Tech Chat > How to do you fit a t2/gt20 to a metro manifold?
george91
Member #: 8932
So i've got my hands on a metro manifold and i'm thinking of using a gt20 or a t2, i know you need a adapter plate but what work is needed to to do this conversion?
I've had a look around but not really found an in depth answer, can anyone explain this for me please?
remove the studs and slot the holes on the turbo and it should line up to the metro bolts
george91
Member #: 8932
ok so the plate is just sandwiched and you use a nut and bolt instead of the stud set up?
you don't need the plate. Have a look at Robert's GT17 thread, there are pic's of how he did it this way.
george91
Member #: 8932
oh ok thats even better, i'll have a look. thanks for the info. :)
miniboy001
Member #: 8367
bucks
is the gt20 the same fitment as the gt17?
ben
They are both T2 style flanges
