| Home > Wanted > SPI Main Relay | |||||||
44 Posts Member #: 9074 Member |
5th Mar, 2011 at 07:24:50pm
Hi-
Edited by jeffreypang911 on 5th Mar, 2011. |
6th Mar, 2011 at 10:15:25am
Should just be an ordinary relay - Halfords or local spares shop job!
On 5th Sep, 2011 Vegard said:
6th Mar, 2011 at 03:04:37pm
Scruffy, the SPi Relay pack is a bespoke Rover item. It contains four relays and has two connectors, a small connector for the coil ciruits and a larger connector for the power circuits.
6th Mar, 2011 at 11:42:01pm
I must have shorted something as I cracked open the relay and there was a huge burn mark and smelled horrid as well. My first hint was the connector - it melted a bit and browned the face!
7th Mar, 2011 at 11:17:41am
The most likely cause is that the manifold heater has failed with a dead short or, the wire itself has come loose and melted to the exhaust. Check the spade connector on the manifold heater, if it is also similarly scorched brown, you need to be looking at the heater element too, otherwise you will fry the new relay pack. On 26th Oct, 2004 TurboDave16v said:
7th Mar, 2011 at 03:52:32pm
Tadah!
