Home > For Sale > clearout
5portsrock
Member #: 2023
nr Portsmouth ,Hampshire
Hi, list of bits for sale. Please pass on to anyone who maybe interested .A
>few pics of some of the bits.More pics to come.
http://s551.photobucket.com/albums/ii474/5portsrock/
>Regards, Fraser
> 1.. 4 off, 8"x10" Spectrum split rims fitted with Hoosier R25B slicks
> (180x7.5-10)...done 2 timed runs and 1 practice run at Loton park. As
> new..£800..SLICKS STORED IN BLACK BAGS UNDER BLANKETS IN MY LOUNGE.
> 2.. 4 off, 7"x10" Spectrum split rims fitted with Dunlop 160-490-10
> slicks (Fr 622 compound, Rr 436 compound) used for half day test day at
> Curborough and 3 practice runs and 1 timed run at Loton park. As new
> ..£700.SLICKS STORED IN BLACK BAGS UNDER BLANKETS IN MY LOUNGE.
> 4.. 4 off, 5"x10" Weller wheels with tyres plenty of life left..£60
> 5.. Tilton 600 series hanging pedal box, steel pedals ,balance bar and
> adjuster cable inc..£120
> 6.. Curley carbon Mk1/2 boot lid new.. £40
> 7.. 2 off, Roversport doors as new, lightened and fitted with Curley
> carbon door cards, not inc windows..£120
> 8.. Turbo cylinder head with valves and springs fitted..£60
> 9.. A+ block ,came out of Metro turbo ,linered 0.020" oversize bore good
> condition ,with all caps..£65
> 11.. Boot floor panel ,Heritage..ideal for repair section goes upto
> centre of shock turret..£15
> 12.. Rear seat back..£5
> 13.. Reat seat pan..£5
> 18.. Starter motor - inertia type nos..£5
> 19.. Mocal oil stat..£10
> 20.. Mocal oil temp sensor housing..£10
> 22.. 1275gt water pump spacer ,used £5
> 23.. Flat dizzy cap and NGK leads..£15
> 24.. Flat dizzy cap..£10
> 25.. Goodridge push on hose ends -12 ,4 x straight ,2 x 90's ,2 x
> 45's..£5ea
> 26.. Master switch resistors x3..£2.50 ea
> 27.. Slimmed down A+ dizzy shaft..£5
> 28.. Hydolastic bump stop kit ,brackets and bump stops, 1 pair of
> bumpstops cut down ..never fitted to a car..£15
> 29.. Magnatron inline magnetic filter trap..£5
> 30.. 3.44 cwp used..£15
> 32.. 3.2 cwp and diff used..£15
> 33.. 3.6 cwp and diff used..£15
> 34.. 2off, Dunlop slicks 160-490-10, 633 compound used..£10
> 35.. 2off, Dunlop wets 160-490-10, used..£10
> 37.. JKD 4.3 cwp for lsd ,damage to edge of 1 tooth ,proffessionally
> blended..£60
> 38.. JKD 3.6 cwp for lsd , semi helicol ,new -never fitted..£150
> 39.. " S " steering arms new, modified to allow bump steer
> adjustment.Supplied with spacers-rod ends and high grade bolts..£40
> 43.. Metro turbo.exhaust manifold and turbo-..£50ea
> 44.. 1275gt 45D4 dizzy..£10
> 45.. Metro turbo dizzy - 2off..£10ea
> 47.. 1275gt/ S 4syncro close ratio gear set 22g1040 laygear. all gears
> and mainshaft..£120
> 48.. 1275gt/ S 4syncro close ratio gear set .15/20/25/29 laygear,gears no
> mainshaft..£100
>50..Pair, 2 1/4" id springs 5" long 120lb as new..£10
>51..Clutch bearing pushrod and HD release bearing £10
>52..Swiftune competition laygear ..new £30
HI ,I FAILED TO ADD BUT ALL PRICES ARE + POSTAGE VERY SORRY !!
Edited by 5portsrock on 6th Mar, 2011.
Interested in 11 and 12
philc
Member #: 1346
bromsgrove
interested in 7, do you come up north at all?
Edited by philc on 6th Mar, 2011.
Funkyp
Member #: 9354
i am interested in 5 (hanging pedal box)
Apparently, I'm Wrong :[
Kean
Member #: 341
aka T2clubby
South Staffs
Would you consider splitting the 7" spectrums from the slicks?
lockfast
Member #: 2775
Aberdeen
Interested in the curley bootlid, can you get me a price to send it to Aberdeen? Thank you.
Star Mag
Member #: 375
Leicestershire
How much to post 32 and 33?
wintersurferuk
Member #: 2208
18.. Starter motor - inertia type nos..£5 yes please! let me know paypal ect... love to getr it this week thanks paul.
Funkyp
Member #: 9354
Also interested in the 2 dizzy's for metro turbo (45)
Thanks
dev 11
Member #: 9393
stoke on trent
hi mate interested in 4. the wellers, 6. the bootlid, and also number 8 and 9, where bouts you live mate?
dev 11
Member #: 9393
stoke on trent
also 43 mate
rosco454
Member #: 5222
Northumberland
Very interested in the doors.Pm sent.
Cheers Ross.
george91
Member #: 8932
i would be interested in 2 if you would consider selling without the tyres?
retro-racer
Member #: 7907
Thame, Oxfordshire.
id be intrested in 45 one turbo dizzy, what are the numbers on it and does it have the amp on the side?
cheers
pickmeup
Member #: 1200
interested in no 5 and 29 if there hasnt already been dibs
I've heard fook all back from this guy!
I'd hazard a guess this list has been on loads of different forums. I'm locking the thread, if the OP wants it re opening they had better start responding to some of the folk.
