| Home > Help Needed / General Tech Chat > N/A hif44 idle problems | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
7th Mar, 2011 at 11:18:21am
Hi lads firstly this is just NA at the moment, im over the twin 1/4's go out of balance all the time.
7th Mar, 2011 at 11:39:27am
Have you got the correct oil in the dash pot?
Edited by apbellamy on 7th Mar, 2011. On 11th Feb, 2015 robert said:
7th Mar, 2011 at 11:46:59am
Sounds like an air leak to me. If something is worth doing, it's worth doing half of. |
7th Mar, 2011 at 11:59:45am
thanks lads.
7th Mar, 2011 at 12:10:19pm
WD40 around any mating faces will tell you if its an air leak. If something is worth doing, it's worth doing half of. |
7th Mar, 2011 at 12:15:24pm
oh thats a good tip john. never thought to do that.. will pop down tomorrow to sort it out.
7th Mar, 2011 at 12:17:28pm
Not heard of a valve. Has he put the correct weight oil in? Any old engine oil will probably be wrong and make the dash pot slower to return On 11th Feb, 2015 robert said:
7th Mar, 2011 at 12:28:21pm
He could be talking about the poppet valve in the butterfly ? The spring can become weak on these & cause problems. Remove it and solder over the hole or replace with a solid disc. |
7th Mar, 2011 at 12:33:53pm
7th Mar, 2011 at 01:01:40pm
yes he put new oil in not sure what, i will check this.
7th Mar, 2011 at 03:22:28pm
Is your thottle cable OK? It could be binding in the casing and not allowing teh thottle to return quickly enough. On 11th Feb, 2015 robert said:
7th Mar, 2011 at 07:47:16pm
i had a problem with the throttle cable when i first did my engine swap where the casing wasnt in the guide hole properly, other than that, make sure the piston slides up and down freely, that the butterfly has a fair amount of tension to close itself and the damper oil is correct, i use a mix of 20w50 and 3in1 oil mixed around 1:1 roughly.
7th Mar, 2011 at 08:40:28pm
poppet valve in the throttle disc, whip it out and put a solid in like said above. (the pic is a poppet valve is in a bike carb throttle disc. these can cause a high idle or slow to return.
8th Mar, 2011 at 08:24:34am
ok lads got the car back from the Dyno.
Edited by NickG on 8th Mar, 2011. |
8th Mar, 2011 at 04:57:20pm
my dizzy was worn and it would tun like a pig.... and move the timing all over the place. it would bounce about 15 deg at idle I run a supercharger and I don't care the TB is on the wrong side.
