Home > Help Needed / General Tech Chat > To everyone that has rubbed the rear arches
pot_dan
Member #: 326
bradford, west yorks
Hi, I have the rear subframe off of the car and I really want to tub the arches. I have seen jimsters thread and I'm happy with what it to be done. My question to those that have done it is,
Is it possible to do it and not have to repaint the rear quater as I want to paint it again next year and not this year. I have sportspack arches and they do cover a lot.
Please can I have opinions and I might decide to do it next year.
Thanks Dan
look at 1380 riches build thread, he did it without damaging the paint.
I will be attempting the same once I pick up my new coilovers.
Clubman Ben
Member #: 8909
North Cornwall
If you warm the paint up it will soften it so the paint won't crack which may help.
If in doubt... flat out! The words of a true legend
pot_dan
Member #: 326
Just seen the title. Bloody predictive txt!
Thanks I will check that thread and soften the paint.
1380rich
Member #: 4755
warwickshire
Yeh I got away with it.. Air saws alot easier if you have one. I used an angle grinder for one side and it took ages.
Good luck with it mate just take your time
Rich
Hammer and chissel works every time. I've just started doing mine, one side finished. I chisseled out the section of the inner arch, then chisseled around the arch seam, leaving all the quarter panel in place. I then folded the lip back on the quarter panel to match the line of the inner arch. Spot or plug welding the plate in on this seam will limit any burning of the paint and any burning will be limited to an area behind the sports pack arches. a qick lick of red oxide, seam sealed, stone chipped, primer and touching in the top coat, with some sort of waxoyl when the arch is refitted will make it good as new. Doing it this way will also prevent any distortion of the quarter panel.
pot_dan
Member #: 326
That's brilliant. Thanks for the help I will pass the info on to my friend that will be doing the welding. And I all be takin pics *smiley*
Thanks.
JT
Member #: 637
Hertfordshire
is tubbing the rear arches a very difficult job?
i think i'll need to do mine as im running 10x7 rims and dont want it to be realy high in the air.
josh
My build thread..
Rick.SPI
Member #: 8027
I'm scared to do mine for now, going to leave it till next winter
I can't delay it any more, I just sold my coilovers and committed to buying the shorter ones!
JT
Member #: 637
Hertfordshire
thats a point the coilovers i have are the lowerd protec type!
will i need to tub my arches?
My build thread..
I put off doing it in 2006 to get the car back on the road quicker, and its taken me til now to actually do it!!
Just do it!
No - I just sold that set and they were fine.
A little bit of rubbing at castle combe, but I was at maximum attack. The spring platforms could have been wound up a whole inch if necessary, but I never got as far as the fine tuning stage due to making the decision to tub!
Edited by minimole23 on 9th Mar, 2011.
