| Home > Help Needed / General Tech Chat > T3 oil return pipe? | |||||||
80 Posts Member #: 4178 Advanced Member Chesterfield |
7th Mar, 2011 at 09:42:16pm
Hi all, i am sorry if this is a stupid question but here goes.
I am nobody, nobody's perfect. Therefore I am perfect |
7th Mar, 2011 at 09:45:37pm
It shouldn't be under any pressure, unless you have loads of crankcase pressure!
7th Mar, 2011 at 09:46:55pm
there's no pressure there, On 28th Aug, 2011 Kean said:
7th Mar, 2011 at 09:50:37pm
no its not under pressure maybe.......... 1 psi if that ....... the silicone hoses dont stand oil for long and the rubber breaks down, but in your case its new have a go at nipping the clips up again
7th Mar, 2011 at 09:52:36pm
Thanks fellas that was my initial thought but there was a lot of oil from somewhere. I will loo around a little more.
7th Mar, 2011 at 09:54:49pm
if you have wanged the clips up tight they could have cut through the pipe. On 28th Aug, 2011 Kean said:
8th Mar, 2011 at 12:45:57pm
Benross has it right (of course) in that silicone hose is not good for oil, unless its fluoro lined. |
