Home > General Chat > leads any good for mj?
welshdan
Member #: 1111
s wales
http://cgi.ebay.co.uk/FORD-FIESTA-KA-1-3-B...=item2c59e01f2e
was browsing ebay and came accross these. look to be correct fitment. how do you tell if they are resistor leads (other than message the seller)?! as it seems this will dictate whether i need resistor or non resistor plugs?
also they look to be a nice length. am running a cossie 2wd ic in front of the plugs so these look to be well suited, unless anyone knows otherwise? im new to megajolt so a little guidence would be much appreciated
cheers chaps,
dan
Edited by welshdan on 10th Mar, 2011.
Yes if you have the right coil pack
Bosch so a good make.
welshdan
Member #: 1111
s wales
cheers, the pack i have have the leads cut on them so still have the coil pack plugs connected. they look to be the same. i may have to look at the part numbers and give them an email. as stated im new to this setup, just wondered what others were using and what peoples opinions were? i did note the make and though my best bet may be with these, instead of some cheaper versions. cheers
welshdan
Member #: 1111
s wales
was thinking of using NGK B8ES. its pretty much a standard engine. hoping to run 10 psi. only thing i have seen is that the width of the porcelain parts of some plugs differ from others.
or even ngk 7s might do in the cold weather :)
Unless your a big boost bad boy 7's should be more than man enough for you.
Or my current favourite
http://cgi.ebay.co.uk/4-Spark-Plugs-fit-Ro...o-/290541091316
