Home > Help Needed / General Tech Chat > T2 oil drain diameter
almichie
Member #: 2065
I'm having a dilema, I'm trying to build an oil drain using the fuel pump apperature. I have plenty of 1/2" copper pipe, but i dont know if it will be big enough for a drain?
Shaft seems nice and snug
jamie@thefatgarage
Member #: 9345
Sheffield
I've used 1/2" pipe before and it was fine. Just make sure it's all as downhill as possible..
Yep anything above about 10mm bore should be fine,
