| Home > Technical Chat > trigger wheel thoughts | ||||||
12th Mar, 2011 at 06:44:27pm
Just been laid in the bath enjoying my hang over, thinking about trigger wheel brackets and what a PITA they are.
12th Mar, 2011 at 06:52:29pm
yep, your bang on,
12th Mar, 2011 at 07:00:17pm
Easiest way would be a lasercut trigger plate bolted between the flywheel and the strap spacer. Modify the spacer whatever the trigger plate thickness is On 19th Jan, 2010 wil_h said:
12th Mar, 2011 at 07:01:59pm
Good idea! On 28th Aug, 2011 Kean said:
12th Mar, 2011 at 07:02:36pm
smashing. Was just giving that some more thought. Shouldn't be too hard for my local talented machinist to spin me up a ring with the teeth machined into it and just bolt it on the outside of the wheel.
12th Mar, 2011 at 07:04:25pm
On 12th Mar, 2011 apbellamy said:
It increases the rotating mass, but in alu it shouldn't be too heavy... Alu won't work. It has to be magnetic. |
12th Mar, 2011 at 07:04:46pm
lasercut would be cheaper.......... Edited by Jason G on 12th Mar, 2011. On 19th Jan, 2010 wil_h said:
12th Mar, 2011 at 07:04:48pm
Beet me to it Jason! good plan for fastening it.
Edited by apbellamy on 12th Mar, 2011. On 11th Feb, 2015 robert said:
12th Mar, 2011 at 07:06:12pm
12th Mar, 2011 at 07:08:07pm
12th Mar, 2011 at 07:15:42pm
I think I'm going to dig out an old flywheel and ruin a transfer case tomorrow On 11th Feb, 2015 robert said:
12th Mar, 2011 at 07:18:46pm
actually I think the wok may be easier to get the sensor in, maybe in the timing hole at 12 o clock. On 28th Aug, 2011 Kean said:
12th Mar, 2011 at 07:23:48pm
another use for the ring that holds down the diaphragm spring ,on a verto ring type ? Edited by robert on 12th Mar, 2011. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
12th Mar, 2011 at 07:27:12pm
That's what I was thinking too, but I'd either need to get the sensor in it at an angle to the wok or have the teeth cut with an angled face so that they where close enough to each other. Poking through the side of the transfer case might be easier - depends on the length of the sensor.
12th Mar, 2011 at 07:31:19pm
On 12th Mar, 2011 robert said:
another use for the ring on a verto ring type ? Sounds sense, but I'll never have enough power in my mini to need an RTS
12th Mar, 2011 at 07:36:59pm
the tooth size isnt that critical, if it looks right it'll work On 28th Aug, 2011 Kean said:
12th Mar, 2011 at 07:39:02pm
Now you got the ball rolling...why not tack weld a trigger wheel plate to the washer on the big bolt that holds the clutch assembly. It would then fit any clutch arrangement............. Edited by Jason G on 12th Mar, 2011. On 19th Jan, 2010 wil_h said:
12th Mar, 2011 at 07:40:03pm
I'm going to have a play tomorrow. I feel some CAD coming on On 11th Feb, 2015 robert said:
12th Mar, 2011 at 07:42:30pm
On 12th Mar, 2011 Jason G said:
Now you got the ball rolling...why not tack weld a trigger wheel plate to the washer on the big bolt that holds the clutch assembly. It would then fit any clutch arrangement............. How much space is there between the WOK and the flywheel? On 11th Feb, 2015 robert said:
12th Mar, 2011 at 07:43:30pm
Either way....its got to be cheaper than some of the flash trigger pullies. Only issue, is dust from the clutch going to cocking up the signal. Would this be a problem?
I'm going to have a play tomorrow. I feel some CAD coming on ![]() Edited by Jason G on 12th Mar, 2011. On 19th Jan, 2010 wil_h said:
12th Mar, 2011 at 07:47:14pm
there are enough production cars running sensor in the flywheel housing, shoud be fine. On 28th Aug, 2011 Kean said:
12th Mar, 2011 at 07:50:08pm
On 12th Mar, 2011 Joe C said:
there are enough production cars running sensor in the flywheel housing, shoud be fine. On 19th Jan, 2010 wil_h said:
12th Mar, 2011 at 08:27:09pm
Create a dxf file using CAD...I'll knock one up in 1mm mildsteel for you.
Now you got the ball rolling...why not tack weld a trigger wheel plate to the washer on the big bolt that holds the clutch assembly. It would then fit any clutch arrangement............. How much space is there between the WOK and the flywheel? On 19th Jan, 2010 wil_h said:
12th Mar, 2011 at 09:03:19pm
12th Mar, 2011 at 09:20:10pm
Nice! Only issue is the size of teeth. Trying to bend them over on a curve will be abit of a mare. On 12th Mar, 2011 Joe C said:
