Home > General Chat > calculating cylinder head spec
sean g
Member #: 9184
lancashire bolton
Hi all
Just stripped my engine and got be thinking about the spec of the new engine.
How do you determine what cylinder head spec is needed for new build (porting-valve size etc )
What will the the shop(porter) need to now about the engine
Any help would be great
Cheers sean
bennyy
Member #: 9037
Doncaster, yorkshire
I would personally get a benross head, he knows what works and does a cracking head.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Yes Benross or TurboPhil seem to do good job.
I was going to say TurboPhil gives good head....... but that sounds wrong is some way!
hazpalmer
Member #: 9038
Carlisle, Cumbria
depends what you want your engine for, speak to phil and benross. And as matt said im sure they will do a good job *wink*
scott the joiner
Member #: 9229
newcastle upon tyne
I've got a turbo phil head & was very impressed of the quality of work & the fact you could just get the chambers opened to lower the comp to run more boost which is all I have done for starters
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
The 4 stroke performance tuning book has all the equations to work out valve size and port size in relation to eachother....
But if your planning on buying one as the other said :)
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
sean g
Member #: 9184
lancashire bolton
Thanks for the suggestions fellas
