Home > Wanted > A couple of carb bits
Im after a 1 /14 SU carb spacer and the elbow that bolts to the back that the air filter bolts on to if anyone has them knocking around?
Matt
I might be able to help, Ill look tomorrow
I've got a load of scrap carbs throwing round, should be able to sort you out
Excellent just let me know if either of you manage to find them.
I may also need a waterpump pulley spacer, just need to double check a few things first.
The black plastic spacer?? Or the otherone, i think i have a 1 1/4 carb spacer in my garrage somewhere with a throtel cable holder on it
Cant find them Matty, must have binned them or ebayed them
tadge44
Member #: 2500
Buckinghamshire
I have some SU carb elbows Matt, if you want to pop over some time
Being useless as ever, I forgot. I should have a waterpump spacer too. I will look tonight
matty a chap at work offered me a brand new never used 1 1/4 carb for a mk1 this week, do you want me to ask how much?
I am a useless twunt. Found my 1 1/4 carb, no spacer and no filter neck.
Found a water pump pulley spacer. PM me an address and I'll chuck it in the post.
Thanks for the offer Neil, Ive got a really good condition early one that im going to use.
Paul - Not to worry, thanks for having a look though.
Apbellamy - I'll send you a pm
Tadge44 - I'll send you a pm
Paul R - yeah thas thats the bit im after. :)
Edited by matty on 18th Mar, 2011.
retro-racer
Member #: 7907
Thame, Oxfordshire.
ive got an carb spacer spare, can post it to you or if your ever in around chinnor you can drop in an pick it up.
