| Home > Help Needed / General Tech Chat > 998 turbo compresion | |||||||
71 Posts Member #: 5754 Advanced Member Bridport Dorset |
16th Mar, 2011 at 08:25:41pm
hi has anyone tried useing the shorter 1098cc pistons in a 998 to lower the compresion ratio im on a budget of as little as possible |
16th Mar, 2011 at 10:19:24pm
Not that I know of. But interesting idea. What is the differance in pin height? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
17th Mar, 2011 at 08:01:15am
i know that they will sit 4-5mm lower in the block when at tdc |
17th Mar, 2011 at 08:06:18am
You'll have to do some calculations then, 4-5 mm is a lot and you may just end up spending all your money skimming the head and block. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
17th Mar, 2011 at 08:55:31am
Or you could find a skimmed 12G295, as most people who do a 998 turbo build look for unskimmed ones which are now getting much harder to find.
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
17th Mar, 2011 at 09:27:43pm
Aren't there some low comp 998 pistons out there ?
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
18th Mar, 2011 at 07:45:20am
Yes, you could use the 20773, it has a 6cc dish. You will need to use buttons on the gudgeon pin though. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th Mar, 2011 at 08:20:07am
I'm building a budget 998 Turbo for the re-shelled 30. I'm using a set of +0.020" 20773s and a heavily skimmed large valve 12G295 that I have laying around. 9:1 compression. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
