Home > General Chat > Turbo oil restrictors
any body use one or think they could be needed, read somewhere that sometimes too much oil can be pushed into the turbo and limting the life?
was looking at getting one to lower the oil in.....
any thoughts?
tadge44
Member #: 2500
Buckinghamshire
Speaking as someone without the theoretical knowledge, I cant see how you can give an oil cooled turbo too much oil unless the seals are passing the oil, or the drain cant cope.
Ben H
Member #: 184
Melton Mowbray, Pie Country
Do you have a problem with turbo life? If mine does 30k miles that will be 10 years at a minimum.
http://www.twin-turbo.co.uk
easier to lower the oil pressure.
wintersurferuk
Member #: 2208
im thinking of one.
read that the t3 dont realy like 40+ psi at idle and if the drain isnt that great, it could pass through and smoke on idel. so was thinking of it to see if it stops me smoking.
Unless you have an issue with oil passing the turbine seal, you do not need a restrictor.
Generally they are only required for ball bearing turbo's which require minimal amounts of oil.
EricsAmerica
Member #: 7891
Annapolis, MD USA
I was going to say that my GTI with a Turbonetics T4 definitely had an issue with too much pressure and needed a restrictor, but as stevieturbo mentions above, mine was a ball bearing setup so that could have been the issue.
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
IMO if the turbo was designed to use one, use it, If not, like in the case of the metro turbo it wasn't so don't, it's simple mate.
Star Mag
Member #: 375
Leicestershire
I have heard of people using them with eBay special turbos to make them last a bit longer!
type49
Member #: 9044
I asked turbo dynamics the very same question regarding a gt2854r
quote
They do have a built in restrictor but we work on the rule, if you are running more than 4 bar of oil pressure you should use a 0.060" restrictor as well or over 6 bar of oil pressure a 0.040" restrictor. If you have high oil pressure (its best to have it checked) I would certainly run with a restrictor to minimize the chances of any oil leakage!
Garrett is the only brand of BB turbo to have the restrictor built in though.
Other brands do not. Although a lot of modern oil journal turbos really dont need much oil either.
wintersurferuk
Member #: 2208
I was thinking of something like this.
http://cgi.ebay.co.uk/Garrett-T3-T34-T35-O...=item5add685b78
only to see if it stops smoking on idle. :/
Have you tried a different turbo surfer? Or double checked your exhaust guides?
wintersurferuk
Member #: 2208
havent tryed a different turbo yet, im pritty sure its the turbo doing the smoking, as when i drain the oil into a bucket it stops.
its only on idle, ive got high oil pressure and a bad oil drain, so i think the two together are the problem.
its only after reading this, i thought i'll give it a go. its not a problem, only when im sat in traffic lol *hehe!*
http://www.d-series.org/forums/forced-indu...oking-idle.html
Do that then *smiley*
Or get a better drain.
wintersurferuk
Member #: 2208
better drain would be the way, when i do a rebuild i'll sort one out.
just looking for a temp fix.
drop your oil out, problem solved.
