| Home > Help Needed / General Tech Chat > Refitting brake and clutch master cylinders | |||||||
18th Mar, 2011 at 08:53:26pm
Currently the car is pretty much a shell and has no dashboard or rails fitted. The pedals are also loose.
![]() 497 Posts Member #: 7641 Senior Member Jersey, CI |
18th Mar, 2011 at 08:57:23pm
if you haven't dropped the split pin ten times, (bonus points for a clevis pin too) banged your head on the dash rail, developed lower back pain from contorting in an un-natural manner and uttered language that would make small children cry, you haven't done it properly...!! :)
Edited by Fortecphil on 18th Mar, 2011. |
18th Mar, 2011 at 09:22:34pm
Sounds just about right to me.
18th Mar, 2011 at 09:28:21pm
Looks like my beer bribe is the best policy then. I will be making sure the split pins are in that's for sure! It will need good brakes.. assuming it doesn't explode the first time I open it up... |
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
18th Mar, 2011 at 09:53:12pm
needle nose pliers are a godsend... with having a fucked clevis pin and not realising i took mine out 4 times in 1 day scratching my head...got pretty good at it in the end, its not too difficult as long as the clevis holes are lined up. i used a long allen key, long arm and angled allowed me to chase the key back thru with the clevis held in the pliers, the split pins easy after that faff too, doesnt have to be folded back on itself either really just opened to stop it passing through David. |
18th Mar, 2011 at 09:56:56pm
http://cgi.ebay.co.uk/CLEVIS-PIN-FITTING-T...=item518db890c6
18th Mar, 2011 at 09:59:50pm
Chasing the allen key through...That sounds like a good plan. Cheers. My bribed assistant will thank you. |
18th Mar, 2011 at 10:04:35pm
@Sprocket:
18th Mar, 2011 at 11:12:04pm
I used an R clip once, never again since I found it kicking around my footwell, I have no idea how long it had been there for too. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
