Home > Help Needed / General Tech Chat > Megajolt is awesome :D but i need a bit more help getting it right.
NickG
Member #: 7912
Australia oi oi oi!
HI everyone!
so i have my mega jolt running very well now & has not missed a beat so much better then a dizzy!!!
i have a few questions- problems running the 1380 map.
it's still N/A for the moment but will be charged very very soon *happy*
I have checked the timing in limp mode, where it is locked to 10 degree's & on my crank i got 6 deegre thats the 3rd tooth down right??
so i would need to offset -4 degree? to match what the engine timing is?
do i set my cranking at 6 degree or 10? if in limp mode it is showing the timing is a static 6 degree when idle with a timing light. ignoring what the mega jolt has to say.
im having starting issues or not started a few days, it takes a fair while to kick over then it runs rough as a nail for a few revs then it picks up great & idles nice, im using a hiff44 carb as always i still warm her up.
lastly it feels like it's not right, it's like it is missing power on the bottom end on acceleration it slightly bogs down & then picks up the revs its very slight but annoying with the (1380 map) MiniSPi2-MD286 map seems alot better and fixed most of these problems.
could it possibly be reading 8 degree before TDc so i maybe only need -2 degree sensor adjustment?
i just gave the MiniSPi2-MD286 map a go & it fixed the bottom end bog i was having a fair bit & revs a bit nicer on low end now.
thanks lads. :)
Nick.
Every one of the teeth on the standard timing marks on an A series engine is worth 4 degrees
NickG
Member #: 7912
Australia oi oi oi!
i was told they go in 2 degree increments.
thats good to know sprocket.
all know is my timing light was showing it was lined up to the 3rd tooth when i hit it with a timing light so 12 degree?
thats really confused me now.
Ah, ok you have a simple light with no read out, Ignore my last coment.
NickG
Member #: 7912
Australia oi oi oi!
ok joe. so 3rd tooth from top to bottom is 8 degree's then?
if they go in 4 degree changes.
so i would need to go -2 on the mega jolt? & cranking advance of 8 to match it all up.
i was told the wrong thing all along!
Edited by NickG on 19th Mar, 2011.
Try it. I got it wrong first time round on van so went other way.
NickG
Member #: 7912
Australia oi oi oi!
You are right whent the other way fixed it..
The bloody torque is awesome!!!
dig-mini
Member #: 9269
Rotherham
When you found tdc did you check this with a dial gauge
This may worth checking just so you know the timing marks on the casing are ok
Craig
