Home > For Sale > selling up
kstead
Member #: 1126
peterborough
Here we go then, for sale as a job lot to start, if i get no luck i'll split it up and i'll take dibbs's from then on. dont be upset if you say i'll have whatever and it goes somwhere elses.
Im looking to sell the lot until further notice :)
pictures to follow as the missus hid the camera charger grrrrr
Mini mayfair i think, currently sorn
Ive owned this for about 7 years, i restored it with new front panel, scuttle, wings and closers, a panels, door skins,rear vallance and various floor repairs. during the resto i had a bulkhead box welded in, it was then sprayed in fiat punto orange c.o.b. at that time it had blended in arches, i changed these to carbon cos they cracked.
once restored i fitted all new hilos, protek adjustable dampers, solid sub mounts, rear camber adjusters, adjustable front ties and links (heavy duty) minifins discs and pads, yoko a0048 tyres on spanking minilites, and its stunning how it sticks to the road and handles!!!!! Dare i say crash proof!!
Engine wise i fitted a 1275 from a mini sprite and then set bout sourcing all the bits to turbo it, this was a metro set up which went on a treat, mpi/spi? tank and 10mm st/st braided flow and return fuel pipe, all was well at low boost but once i added a bleed valve the temp shot up, a new two core rad and a thermo stat/fan etc sorted that so more boost followed, at the limit of the clutch now (well over it tbh) in anticipation of the new engine going in i have cut the slam panel out and was in the proccess of fitting a 4x4 cossy intercooler and dinky alternator, thats where it stands.
Interior is stripped out with monoco seats, 2"4 point safty devices harnesses (lurvly) lowered collum, centre dash wth a few other gauges about.
virtualy ready to go in is my project engine, rebored to 1380, phase 2 regrind, reground crank, centre oil pick up rebuilt gearbox, new double roller, and 2 baulk rings, the rest were fine, new minispares 4 pin diff, obviously all new seals etc, benross's top spec head which is good for over 200 whatsimejobs, hif 44 carb rebuilt to turbo spec, modded plenum and turbo pipe by giofly?? i think,
rebuilt t3 with all new stainless studs etc. and a flowed elbow by benross, Trigger wheels wheel and megajolt lite is all there and ready to be fitted, clutch wise we have a new ultra light steel flywheel and back plate, and an ap paddle plate.
Also in the workshop i have the following, 2x turbo blocks, cranks, heads and gearboxes and various plumbing,pipework etc. several carbs of varying sizes a couple of gt17 turbos. various intercoolers new and old. Phew theres a lot of stuff there.
Anyone is welcome to call me or come and see, if you are serious you'll come an have a butchers anyway, i wont bite i promise. 07973268187
4k anyone?
Will get photos later but the missus is busting my balls to go out now as its taken me about an hour to write this...
bennyy
Member #: 9037
Doncaster, yorkshire
not a bad price for all the bits, good luck with the sale, if you decide to split i ll be throwing a few hundred your way for rebuilt gearbox with the 4 pin diff, lightened fly and ap plate :)
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
almichie
Member #: 2065
I'd be nterested in the head off benross and a gt17 if it gets split...
Shaft seems nice and snug
Utking
Member #: 9342
Southern Norway.
oh, some nice stuff over there for sure!
I would also be interested in the benross head :)
Some pics may help *wink*
crazykillerbunny
Member #: 5122
Boston, Lincolnshire
I would be up for the megajolt if splitting
hazpalmer
Member #: 9038
Carlisle, Cumbria
id be after some bits if you decide to break.
Utking
Member #: 9342
Southern Norway.
Pm sent about some stuff :)
Amp
Member #: 7856
I'd be interested in a few bits as well if you came to break it, namely the clutch, fuel lines, alternator and the minifins!
Edited by Amp on 20th Mar, 2011.
philc
Member #: 1346
bromsgrove
as in general chat interested in roll cage if you split, also your braided fuel lines
Edited by philc on 19th Mar, 2011.
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
definatly interested in some bits if you break
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
kstead
Member #: 1126
peterborough
this should show the car, loads of the motor being built up on my photobucket
just_jack
Member #: 2928
peterborough
interested in the door cards if they are real carbon.. could pick up as well and im sure your close peterborough isnt that big
ps and some boost pipe and a gt17
Edited by just_jack on 19th Mar, 2011.
Jack Jones
lockfast
Member #: 2775
Aberdeen
Interested in the arches if you decide to split it. Possibly the wheels and seats too
Edited by lockfast on 19th Mar, 2011.
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
if you split, i could really use your gauge pod, with gauges or without, I have a hard time finding those here in the states for less than my left nut.
-James
marsh_84
Member #: 9355
ntown
hi, i'd definatly be interested in the fuel tank if do do decide to split.cheers.
Edited by marsh_84 on 20th Mar, 2011.
just_jack
Member #: 2928
peterborough
any news on this kstead?
thanks
jack
Jack Jones
kstead
Member #: 1126
peterborough
Hey guys. Not had much interest as one.
Where do you recon I'd be price wise jus for the car with a year t&t ???? £2500/3000????
Utking
Member #: 9342
Southern Norway.
Hmm, if you still split i could use a fuel regulator :)
bennyy
Member #: 9037
probably be worth more to the right buyer, theres a lot of kit there for the money, finding someone who is after it all in one is like finding a needle in a haystack lol
carts60
Member #: 9335
Bromley, SE London
I'd be very interested in a lot of the stuff you have if you split it all - like your rebuilt 1380 turbo engine depending on price, if not that, then a turbo block, crank, head, gearbox, a GT17, possibly an intercooler too lol
I wish i could sell my mini now and buy yours with all the bits. p/x?
kstead
Member #: 1126
peterborough
Thanks carts but not really looking for another mini just yet, if you had a tt roadster or boxster that would be a different matter. Its been decided tha the mini doesnt get enough use by me on my own so a chick friendly toy it is....
bennyy
Member #: 9037
Any more news on this?
