| Home > Help Needed / General Tech Chat > bore wash or valve guides | |||||||
14 Posts Member #: 2352 Member staffs |
20th Mar, 2011 at 06:57:46pm
Been having problems with my engine smoking. Block, head and turbo have not long been rebuilt. It smokes when it has been standing on tickover for a while but the smoke is grey. It also does it when it is on overun and when you rev it, the smoke is still grey but has a hint of blue to it now and then. Had it running n/a but still the same. So i took it back to the place where i had it rebuilt (toovey) he just took a spark plug out and said borewash, put the turbo back on and get it set up. I then took it a part and found oil in the exhaust port. To get a closer look i took the head off and could see oil all around the valve guide and on the valve stem where it goes into the guide. Phoned up toovey and they said borewash again. Taking the head to show them this week but i thought i would see what other people think. Hopefuly i have attached two pictures for you to look at. Honing marks can still be seen. Should you have any side to side play in the pistons. Another thing i could see are small traces of oil around the valve stems where they meet the valve guide in a couple of the inlet ports and on one of the other exhaust valve. When i took the turbo off there was no traces of oil in the manifold and people have followed me and it didn't smoke at all. It just started as i got close to almost doing my 1000miles of running it in. Thanks for your time. |
20th Mar, 2011 at 07:06:36pm
No pictures, but it sounds like the problem we had on our van.
20th Mar, 2011 at 07:07:48pm
Sorry but seem to be having trouble uploading pictures at the moment says its uploaded then nothing happens. Bloody computers |
20th Mar, 2011 at 07:24:35pm
If you have the head off, it will be easy to see if it is bore wash or not. On 26th Oct, 2004 TurboDave16v said:
20th Mar, 2011 at 08:39:43pm
Fingers crossed this works |
20th Mar, 2011 at 08:40:07pm
Still no pictures :( |
20th Mar, 2011 at 08:41:00pm
try uploading them to photobucket? or facebook. Edited by Joe C on 20th Mar, 2011. On 28th Aug, 2011 Kean said:
20th Mar, 2011 at 08:48:29pm
top tip cheers!
20th Mar, 2011 at 08:50:55pm
If you are using the attachment feature in the 'post' dialogue, it does not like any picture file with .JPG, it needs to be lower case .jpg, then it will upload. also worth making sure the file you are trying to upload is a reasonable size, nothing humungous and nothing tiny. On 26th Oct, 2004 TurboDave16v said:
20th Mar, 2011 at 08:54:59pm
another hint,
71 Posts Member #: 316 Advanced Member Staffs |
20th Mar, 2011 at 09:11:29pm
20th Mar, 2011 at 11:11:52pm
Looks like the guides to me dude. If something is worth doing, it's worth doing half of. |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
21st Mar, 2011 at 12:52:34pm
Sounds like valve guides and valve stem seals to me.
Edited by turbominivanman on 21st Mar, 2011. Minivanless, but reluctantly happy living with the decision. There'll be another one day.
21st Mar, 2011 at 06:26:10pm
Thanks for all your thoughts. I thought it was valve guides as well. Just dropped it off and i've just got to wait what they are going to do (boss wasn't in). Chears |
21st Mar, 2011 at 07:09:34pm
best bit of advise I can give is, never take an expert as being right,
21st Mar, 2011 at 08:01:00pm
Yeah them lines are just water. Chears |
