| Home > Help Needed / General Tech Chat > carb or injection | |||||||
15 Posts Member #: 9402 Member |
20th Mar, 2011 at 08:51:03pm
ive currently got a 1.3 cooper injection and somebody said i should change to carbs if so how hard is it to change and also is it any better on performance and fuel. |
20th Mar, 2011 at 08:56:55pm
On 20th Mar, 2011 minichipper said:
ive currently got a 1.3 cooper injection and somebody said i should change to carbs if so how hard is it to change and also is it any better on performance and fuel. Depends what you want. But in general, it will be better on fuel and not a restriction to power 'til you have plenty. A lot of people who think they understand carbs and don't understand injection would give advise to change to a carb. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
20th Mar, 2011 at 11:16:48pm
I'd much prefer and injection setup If something is worth doing, it's worth doing half of. |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
21st Mar, 2011 at 12:42:02am
My second version of my engine will most definitly be injected. For now it's carbd and 5 port for cost reasons. It's a long way off v2 and not quite complete at v1 yet lol On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
21st Mar, 2011 at 12:42:48am
21st Mar, 2011 at 11:51:47am
I have seen people in my local club convert to carb as the SPI injection had a failure and the parts were either hard or too expensive to source. They only use the car as a fun car and not a daily drive.
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
21st Mar, 2011 at 05:45:38pm
Carb over standard injection. However if your talking about throttle bodies, ect then injection everytime (budget allowing) i would be injection if i could afford it Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
21st Mar, 2011 at 05:46:43pm
Injection for me On 11th Feb, 2015 robert said:
21st Mar, 2011 at 06:17:48pm
On 21st Mar, 2011 Gaball said:
Carb over standard injection. However if your talking about throttle bodies, ect then injection everytime (budget allowing) i would be injection if i could afford it ![]() Nothing wrong with standard injection. I recon I can easily get 110hp out of a factory injection system on a 1400 with a 'mild' cam. Thats far better than a lot of 1380's with a 286 cam and a carb!! On 26th Oct, 2004 TurboDave16v said:
4 Posts Member #: 4745 Junior Member Birkin, Knottingley, Yorkshire |
22nd Mar, 2011 at 03:53:38am
Alright Danny! |
22nd Mar, 2011 at 09:20:13am
Didn't say there was anything wrong with it just, more power would be achievable with a carb seen 1293s on carbs with more power then 110 On 21st Mar, 2011 Sprocket said:
Carb over standard injection. However if your talking about throttle bodies, ect then injection everytime (budget allowing) i would be injection if i could afford it ![]() Nothing wrong with standard injection. I recon I can easily get 110hp out of a factory injection system on a 1400 with a 'mild' cam. Thats far better than a lot of 1380's with a 286 cam and a carb!! Gaball said:
Carbon but plug? |
22nd Mar, 2011 at 12:14:30pm
The way I see it is that if you understand injection you wonder why people who don't, like carbs.
http://www.twin-turbo.co.uk
22nd Mar, 2011 at 01:46:20pm
Carbs are quicker to set up i would imagine its the main reason. Not to mention price.
On 22nd Mar, 2011 Ben H said:
The way I see it is that if you understand injection you wonder why people who don't, like carbs. Most people now understand that mapped ignition is better, but how long did it take to convince most. Gaball said:
Carbon but plug? |
22nd Mar, 2011 at 02:06:02pm
I'd like to see a properly set up webber set up quicker than injection. For that matter any carb. Accepting the difficulties with the 5 port, there is no reason to use a cab these days, unless you are racing and the class forces you to. http://www.twin-turbo.co.uk
22nd Mar, 2011 at 02:51:52pm
Accepting the difficulties with the 5 port, there is no reason to use a cab these days, unless you are racing and the class forces you to. What about originality, cost, simplicity (relative), knowledge, ability to make/install/tune etc etc On 11th Feb, 2015 robert said:
22nd Mar, 2011 at 06:40:11pm
On 22nd Mar, 2011 deemo said:
Sprocket I don't think 110HP is possible with just a cam and rebore, well I'd be very surprised. People seem to be managing around 80HP with a worked head, hi-lift rockers, exhaust, filter ect 100 seems to be the limit. IIRC you managed 100hp on your SPI? What spec was that? Your going to make me look silly and tell me you have got 110 nanas now aren't you... 100bhp on the 1400 with a Kent 274 and well prepped 35/29 valve head, and cat. The way I look at this is that extra 10hp could well be in a larger valve head, larger exhaust manifold, a kent 274SP cam and ditch the cat. The ECU while factory standard, does not come from a Mini but is a direct fit. Its a while off, but the gear is on the shelf, the car is years from being ready, but, if I get the engine together, I have access to an engine dyno so who knows
22nd Mar, 2011 at 08:50:38pm
Dam you to think of more reasons, but apart from originality all the others make no odds.
Accepting the difficulties with the 5 port, there is no reason to use a cab these days, unless you are racing and the class forces you to. What about originality, cost, simplicity (relative), knowledge, ability to make/install/tune etc etc http://www.twin-turbo.co.uk
22nd Mar, 2011 at 09:04:22pm
You need the ££££ tho. I run a supercharger and I don't care the TB is on the wrong side.
22nd Mar, 2011 at 09:06:57pm
I just want to add that filing needles is definitely not a simple or quick way of tuning fuel delivery. Hitting the up or down arrow on a computer keyboard seems trivial in comparison.
22nd Mar, 2011 at 09:08:17pm
On 22nd Mar, 2011 gr4h4m said:
You need the ££££ tho. There are alternatives. And a brand new complete carb setup is not cheap either. Jean |
23rd Mar, 2011 at 10:42:14am
Carbs are not cheap but they are cheaper then injection by far.
Carbon but plug? |
23rd Mar, 2011 at 12:47:59pm
On 23rd Mar, 2011 Gaball said:
I am aware injection not to be a black art however carb are still simpler and quicker to set up. This is my whole argument. Cars are not easier or quicker to set up. They are more difficult and slower, if you do it right. It is a fundamental misunderstanding of cabs and injection that perpetuates this myth. http://www.twin-turbo.co.uk
23rd Mar, 2011 at 03:09:41pm
Its no myth a whole day can be spent fitting an injection system and then creating a map from new.
I am aware injection not to be a black art however carb are still simpler and quicker to set up. This is my whole argument. Cars are not easier or quicker to set up. They are more difficult and slower, if you do it right. It is a fundamental misunderstanding of cabs and injection that perpetuates this myth. Gaball said:
Carbon but plug? |
23rd Mar, 2011 at 05:36:20pm
Once you've used injection, even complicated 5 port stuff, then you will never go back to carbs.
23rd Mar, 2011 at 10:24:27pm
IMO carbs (and a dizzy) are great to bung on and get somthing running, but as for ease of tuning, injetion wins hands down. Edited by Joe C on 23rd Mar, 2011. On 28th Aug, 2011 Kean said:
