Home > For Sale > complete megajolt system
PaulW
Member #: 373
Leeds
All you need to get you going with megajolt. The map that is in the ecu is for a 1330 N/A engine. You get.
* Megajolt ECU
* coil pack and connector
* crank sensor and connector
* EDIS Ignition module
* Coil pack
* Loom
* Set of 8mm spark plug leads
* Custom A-series crank sensor bracket and spacer bracket
* trigger wheel fitted to bottom pulley
sold
Paul
Edited by PaulW on 22nd Mar, 2011.
"I'll get there in the end"
Dark Angel
Member #: 8965
MIldenhall, Suffolk
I'll take it. Send me your paypal.
mike174
Member #: 9188
Brighton
ill take it if it falls through
Mike
PaulW
Member #: 373
Leeds
now sold
