Page: |
Home > A-Series EFI / Injection > Megasquirt MS3 & MS3X | |||||||
22nd Sep, 2011 at 10:20:32am
Did we decide that it was possible to common up two injector drivers to a single injector?
22nd Sep, 2011 at 11:49:40am
I think we decided that it was the way Rover did it with MEMS (to be able to use a "standard" 4 channel MEMS driving two injectors) as that is what the MPI wiring diagram clearly shows, and that if the MS3X uses normal FETs or MOSFETs to drive the injectors, the same should apply.
22nd Sep, 2011 at 11:57:53am
This is them:
22nd Sep, 2011 at 12:39:38pm
Looking at the datasheet I don't think it will be a problem having them paralleled but hopefully Jean will see this post and confirm one way or the other. Schrödinger's cat - so which one am I ??? |
22nd Sep, 2011 at 02:28:16pm
I don't see an issue with doing that.
22nd Sep, 2011 at 02:29:27pm
Well, I can look forward to a bit of closed loopiness :) Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Sep, 2011 at 02:31:30pm
I should add that I'm curious to see what you want to do. Is it simply the dual pulse mode? The difference with MS2/Extra is that you'll have to use the same timing for inner and outer cylinders. But you can play with trim so you should be able to get the correct fueling.
22nd Sep, 2011 at 03:17:26pm
Exactomundo :)
114 Posts Member #: 9645 Advanced Member South Wales |
22nd Nov, 2011 at 09:11:46am
Sorry for dragging up an old post, but I'm just trying to understand the difference between the MS2 and MS3 injector timing.
22nd Nov, 2011 at 09:19:00am
You are correct.
28th Nov, 2011 at 11:06:09am
Thanks for that it's appreciated, I'm slowly starting to understand the basics!
28th Nov, 2011 at 11:12:20am
The ECU is setup for 4 cylinder sequential, with staged secondaries.
28th Nov, 2011 at 11:24:37am
Thanks for that.
28th Nov, 2011 at 11:31:06am
Correct.
29th May, 2012 at 09:29:37am
On 24th Mar, 2011 Paul S said:
There are other ways in which it could be used with siamesed port injection. You can even assign O2 sensors to particular injectors and run closed loop AFR control. Think about it. can you run outer ports on one wide band and the inner on another and do like a twin mirror image closed loop AFR control ? |
29th May, 2012 at 09:41:53am
Yes, you could. You would have to use the cylinder trim feature.
30th May, 2012 at 07:28:25am
cool as paul im really thinking that id like to have a go at doing a staged injection turbo mini with the 1098 like what you have done with the 998 3 injectors per port i have been looking at the MS3X ecu but i think i have lot to learn about it are there any places i can look at the programing like how to kind of things and what parts are completable like injectors sensors and coils id like to do a cop set up i live making stuff and i have decant welding skills so manifolds wont be to much trouble unless i do a alu inlet might get that welded by a pro donno for now i need to sort out what id like to do and how im gona do it.. |
30th May, 2012 at 08:37:59am
There is quite a bit of info on here about most of the items you said if you have a search. I think the MS is set up to run with GM sensors, but you can run others if you have a calibration curve. I found the MS manual and forum really helpful to understand how it all works and it also gives details on how to connect it up. |
30th May, 2012 at 09:07:27am
Have you read our build guide?
Edited by Paul S on 30th May, 2012. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
31st May, 2012 at 07:16:19am
On 30th May, 2012 Paul S said:
Have you read our build guide? http://www.turbominis.co.uk/forums/index.php?p=vt&tid=329735 It's mainly MS2 based but a lot applies to the MS3. Also recommend Dave Walkers book for an overview of EFi. thanks paul ill have a look at dave walkers book also that PDF file in the link only has the contents page ?? anyone else have this problem or is it the operator? |
31st May, 2012 at 08:03:45am
Wrong thread, that was just the contents page for comments
1st Dec, 2012 at 10:34:06am
New MS3 Pro. All the good points of the MS3 & 3X but with better tach circuits and waterproof case and connectors.
1st Dec, 2012 at 01:30:30pm
Looking at the Pro it has a very limited market imo just because of cost, cost would be more than an Emerald or MBE
Forum Mod 10979 Posts Member #: 17 ***16*** SouthPark, Colorado |
1st Dec, 2012 at 03:14:01pm
On 1st Dec, 2012 wolfie said:
Looking at the Pro it has a very limited market imo just because of cost, cost would be more than an Emerald or MBE They should just design a case with ampseal for the ms1/2 or 3-3x for the DIYer this would appeal much more imo Totally agree. On 17th Nov, 2014 Tom Fenton said:
1st Dec, 2012 at 03:38:07pm
Looking at the Pro it has a very limited market imo just because of cost, cost would be more than an Emerald or MBE They should just design a case with ampseal for the ms1/2 or 3-3x for the DIYer this would appeal much more imo I think you're wrong on the first part because you're not looking at the right market. That may be true for Europe or 4-cylinder applications but that's not likely to be the primary target. Look at the feature set and compare it with the other ECUs: http://www.diyautotune.com/ms3-pro.html. As for using an Ampseal connector, there are two problems. First it is physically large so if you keep the ECU a DIY offer, that means a larger case especially when you're talking about the MS3. The second problem is cost and DIYers are reluctant to pay more even if they complain about the supposedly inappropriate connector. Having said that, there are dozens of ways things could be improved to get a better DIY version for the MS2 and the MS3. Unfortunately, that won't happen. Jean |
Page: |
