| Home > Beginners Tech > My turbo engine wont rev! help please...... turbo mini shorty! | |||||||
8 Posts Member #: 9413 Junior Member |
26th Mar, 2011 at 08:11:11pm
I have just bought a mini shorty and it came with a metro turbo engine in it, was working fine until yesterday.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
26th Mar, 2011 at 08:23:47pm
is it megajolt timing or dizzy could be timing slipped?? Done now needs redoing lol |
26th Mar, 2011 at 08:26:37pm
does it pull through the bogginess,
Yes i moved to the darkside |
26th Mar, 2011 at 08:26:52pm
oil in the dash pot? I run a supercharger and I don't care the TB is on the wrong side.
26th Mar, 2011 at 09:04:05pm
Running really lean? Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
26th Mar, 2011 at 10:08:11pm
On 26th Mar, 2011 wng691s clubby said:
is it megajolt timing or dizzy could be timing slipped?? it cant have slipped, the dizzy is in solid. Its standard as far as i can see. |
26th Mar, 2011 at 10:10:42pm
On 26th Mar, 2011 Brett said:
does it pull through the bogginess, does pulling the choke out as it bogs help do you have a boost gauge fitted/ what is it doing when it bogs no, its just almost dies, when you let off the accelerator its idles fine again. it does help a bit when the choke is out, but give it anymore than choke and it bogs down again. there is not boost gauge. |
26th Mar, 2011 at 10:11:51pm
On 26th Mar, 2011 gr4h4m said:
oil in the dash pot? there is oil in it, not sure how much, should it be brimming? when i press down on the plunger with the cap off it will rev though!!!! |
547 Posts Member #: 2928 Post Whore peterborough |
26th Mar, 2011 at 10:46:13pm
Oil Thickness, maybe a little to thin? Jack Jones |
26th Mar, 2011 at 10:56:07pm
On 26th Mar, 2011 just_jack said:
Oil Thickness, maybe a little to thin? dashpot oil do you mean? or engine oil? |
107 Posts Member #: 9276 Advanced Member Darlington north east |
26th Mar, 2011 at 11:02:30pm
mixture screw, turn it clockwise to make it richer.
26th Mar, 2011 at 11:41:29pm
On 26th Mar, 2011 andyuk1275 said:
mixture screw, turn it clockwise to make it richer. also check the plugs if there black its too rich and needs to be turned anti clockwise :) dont want to touch the mixture screw because it was working fine friday. |
27th Mar, 2011 at 12:30:22am
Sorry bud should've said, dashpot oil, if it's too thin could have no effect and the needle would just raise causing the engine to overfuel making it bog down when throttling up
Oil Thickness, maybe a little to thin? dashpot oil do you mean? or engine oil? Jack Jones |
27th Mar, 2011 at 02:35:46am
On 27th Mar, 2011 just_jack said:
Sorry bud should've said, dashpot oil, if it's too thin could have no effect and the needle would just raise causing the engine to overfuel making it bog down when throttling up On 26th Mar, 2011 eirianprice said: On 26th Mar, 2011 just_jack said:
Oil Thickness, maybe a little to thin? dashpot oil do you mean? or engine oil? yeh been thinking that would be an issue, just strange its happened when it was working the day before. then again the engine did run hot and maybe its just free'd itself up. ill give it a go tomoz, ill try with some good old 20*50 |
27th Mar, 2011 at 10:05:41am
Its too lean, if you don't want to touch the mix screw, just count the number of turns, then turn the same amount back. If it makes no difference Audi s4 b5 - 470bhp & 486ft lbs
27th Mar, 2011 at 11:31:22am
got the thing running ok now, there was oil in the dashpot but it must have been too thin! |
