| Home > General Chat > UPDATED 04/04/2011; O/T; now looking at mondeo | |||||||
28th Mar, 2011 at 12:44:14pm
looking for any guidance here; I'm looking to buy a car for my brother's other half as a new family car for them. It doesn't have to be all singing and dancing, just something practical for getting the baby in and out the back and a big boot for all the crap that seems to come with a family these days.
Edited by Rob Gavin on 4th Apr, 2011. |
28th Mar, 2011 at 12:53:41pm
Wifey has an 04 plate civic, apart from the battery it's been bullet proof.
28th Mar, 2011 at 01:16:48pm
never pick them up on recovery if that helps Crystal Sound Audio said:
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
28th Mar, 2011 at 04:00:26pm
Only issues I ever heard with the older b16 is piston rings going and that was one count so the reliability is echoed there!
Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
28th Mar, 2011 at 04:02:53pm
cheers guys- helpful as always.
On 28th Mar, 2011 Gaball said:
Only issues I ever heard with the older b16 is piston rings going and that was one count so the reliability is echoed there! The older ones have a bit more poke then the newer iVTEC mainly I think to do with weight But they have the usual jap reliability Failing that what about a late 90s polo? |
28th Mar, 2011 at 06:15:37pm
I had an even older crx which I miss after only 2 weeks. It did not put a foot wrong in 2 years, and apart from a battery not in 4 years for the previous owner. Regarding the piston ring comment I don't think using a litre of oil per 6000 mile change for an engine that revs up to 8500rpm on 139k is bad going!
Edited by minimole23 on 28th Mar, 2011. On 7th Oct, 2010 5haneJ said:
28th Mar, 2011 at 06:19:36pm
Check for rot in the rear arches and front corners for the front wheel arches. On 11th Feb, 2015 robert said:
28th Mar, 2011 at 07:37:56pm
dont worry too much about the engine, played about with them for a while with a mate, it took him fooking ages to kill his.
Yes i moved to the darkside |
28th Mar, 2011 at 09:12:57pm
had an accord with the 2.0 d-series, on 180kmiles i kicked its hole in every day for 2 years and it never missed a beat, even when i smashed it, totalling the radiator she still drove to the scrappys without incident. great cars, though the newer shape 4-doors are probably a bit out of budget, they dont rot like civics do. turbo 16v k-series 11.9@118.9 :)
28th Mar, 2011 at 11:44:14pm
Sounds daft...I think alot of Hyundai's are basically Honda running gear.....cheap to buy Edited by Jason G on 28th Mar, 2011. On 19th Jan, 2010 wil_h said:
29th Mar, 2011 at 12:10:30am
Tbf my mates was getting through a litre a week lol but come to think of it that was a non VTec anyway don't think I ever heard of one going wrong without being pushed hard!
On 28th Mar, 2011 minimole23 said:
I had an even older crx which I miss after only 2 weeks. It did not put a foot wrong in 2 years, and apart from a battery not in 4 years for the previous owner. Regarding the piston ring comment I don't think using a litre of oil per 6000 mile change for an engine that revs up to 8500rpm on 139k is bad going! I think the 1.6 aerodecks had a single cam vtec engine, the vti's had the 1800 DOHC one. I don't know about gearboxes on the later civics but check it does not crunch when in vtec, as on the early ones the sycros can get tired. At 100k I wouldn't think there would be a problem, as a fair few years of development would have taken place since the first generation vtec gearbox. Gaball said:
Carbon but plug? |
29th Mar, 2011 at 09:09:04am
cheers guys, the civic looked good on paper but my wife, the one that isn't paying for it or driving it, has decided its too old a design and doesn't like the look of it.
29th Mar, 2011 at 09:18:23am
I've had a 51 plate 2.0 Zetec Focus from new. Now done 130K. Very few problems except the usual plus, batteries, alternator, power steering pump and the broken rear spring.
29th Mar, 2011 at 12:02:47pm
Paul
29th Mar, 2011 at 12:14:33pm
Drive really steady, then nearly 40mpg is possible.
857 Posts Member #: 1778 Post Whore Northants |
29th Mar, 2011 at 12:22:56pm
I drive mine 10 miles each way to and from work, not the most economic driving style and get nearly 300 miles out of a tank which is around £65 vmax, never brimmed it and accurately worked out mpg |
![]() 1596 Posts Member #: 8027 Post Whore Thrapston, Kettering, Northants NN14 |
29th Mar, 2011 at 09:26:22pm
I had a 1.8 zetec focus, lovely car to drive but I got a bad apple which had electrical problems making it a but dangerous at times, especially at night on motorways, apart from that it was a decent car. If it was 3 door and didn't have the electrical problems I would have kept it no doubt. Edited by Rick.SPI on 29th Mar, 2011. On 17th Feb, 2011 apbellamy said:
I popped my first one out the other day... |
29th Mar, 2011 at 09:53:22pm
OK - looks like the focus is a good option; I'll give the noe i've seen a call tomorrow and have a look
29th Mar, 2011 at 10:32:31pm
clutch release bearings leaking, gearbox off job to fix, springs, speedo not working (usually speedo sender in gearbox which is a bitch to get out), are the only reoccurring problems i see, and the only one worth concering yourself over is teh clutch slave/bearing, as everything else is cheap to sort and run of the mill. turbo 16v k-series 11.9@118.9 :)
29th Mar, 2011 at 10:38:02pm
cheers Denis |
4th Apr, 2011 at 10:59:57am
OK guys - the search continues; I'm now looking at Mondeos and have arranged to look at a 1.8 Zetec estate this evening; its one of the newer shape cars on a 51 plate with circa 100k on the clock. Price is £900.
4th Apr, 2011 at 11:10:02am
Steer clear of the TDCI models at that age. Flywheel and turbo failures are common and expensive. On 11th Feb, 2015 robert said:
4th Apr, 2011 at 12:41:38pm
yip - saw that - in honesty all the diesels at that sort of price are either intergallactic mileage or too expensive |
4th Apr, 2011 at 12:53:33pm
Rob, brother in law has an 03 plate 1600 Focus Ghia 5 door that he is on about selling- he recently got a company car. Not sure how much it would be though, I can find out, what is your budget?
4th Apr, 2011 at 01:21:05pm
Tom, the budget is around £1k - could stretch a bit more but it would depend on the car
A friend bought a Kia C'd diesel....have to say, really can't fault it.
