Home > General Chat > cleaning the inside of a fuel tank
for those who have welded new take offs to the std steel tank what did you wash it out with just water?
If you really want to get it clean that POR15 stuff is excelent. mine looked like it had been galvanised after.
In my case, water (high pressure washer) followed by some water soluble degreaser, as the water soluble degreasers leave a very thin oily film (which stops rust for a while) once they have evaporated. Once the degreaser evaporated, installed and filled ASAP.
cheers guys, its mainly the fillings and general swarf from drilling, grinding and welding i want to wash out but not the rusting afterwards
what do you think about a liberal dose of wd40 or the like on the inside and a very good swill out before first fill?
tadge44
Member #: 2500
Buckinghamshire
I just use water and then a bit of meths or thinners to rinse out the water thats left.If you are worried about leaving any water in there, just blow warm air through with a hairdryer or hot air paintstripper.
Brett, throw a match in, cleans it in seconds !!!
rick
Midas
Member #: 7555
I had to weld a damaged tank recently, replacement wasn't an option as you can't buy new ones for this car.
I started by jet washing using a powerful detergent, rinsed and then given a good soaking with a caustic soda solution before drying with warm air. A magnet on a stick is useful for gathering any swarf as it washes around.
While welding I filled the tank with a CO2/Argon mix as extra insurance. The tank was then sealed with Frosts tank sealant and then left to dry for a couple of weeks, I've already found out the hard way that this stuff turns into jelly and blocks fuel lines if the tank is filled before it's completely dry. The good news is that any debris still in the tank is encapsulated in the sealant.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I've always just rinsed it out with petrol...change the fuel filter regular...simples :)
On 19th Jan, 2010 wil_h said:
rick
I am with rick it may also clean your face off *surprised**happy**surprised**happy*
