Home > Help Needed / General Tech Chat > cleaning pistons
Nick
Member #: 154
Midlands
anyone got any do's and don'ts with regards to cleaning up my piston crowns as i've just pulled my engine out to split the box to have it rebuilt. trouble is i dont want to take em out of the bores as last time i tried to put pistons in i broke 2 rings, costly mistake!
i was thinking of using a soft brass brush in my drill but what about all the carbon, will it fook up me bores/rings if it goes down the sides?
its done about 3000 miles since it was built, had the head of after 500 miles to swap for my new one and there was only a small amount of build up which wiped off with a rag.
P.S. let me know if you spot anything dodgy as i havent had chance to have a proper look at it yet.
Doodmeister
Member #: 149
Alberta, Canada
How about some of your mums Mr. Muscle from under the kitchen sink and a scotchbrite pad should work a treat if you spray it on and leave it for an hour or so.
And it won't harm a thing :)
Nick
Member #: 154
Midlands
cool, i'll get it cleaned up later on then, cheers dude.
I just use a rag with some thinners or petrol on to get the worst off, as with in a few miles it will be back all carboned up again!
bud666 looking at the pics buddy it looks like to me that N0 4 is very oily!??
in the head and top of piston
it may be prudent to pull that piston for signes of ring damage, ring land damage etc
also on number 1 as well ?
Nick
Member #: 154
Midlands
yeah i think i may pull em out then, the bores are fine, no marks/scoring etc. ive been running it at 10psi so havent gone wild with it, plus it was RR'd before i booted it so hopefully it should all still be ok.
turbo hogster
Member #: 178
stowmaket suffolk
i would check the valve guides and seals first before you pull the pistons as it could just be oli drain from them sfter you have shut of the engine, if it was thats bad you would noticed it during normal running , if it was the rings.
just a thought as you proberly dont need excessive hassel and expense.
Nick
Member #: 154
Midlands
well the head is only 6 months 2500 miles old. but come to think of it, i did get a puff of blue smoke everytime i started it when warm, didnt get any first thing though when it was cold to suggest stem seals.
Dangerous
Member #: 417
You could get it converted to 11 stud
turbo hogster
Member #: 178
stowmaket suffolk
yep seams like a bit of oil drain down then, well that should save a bit of cash,
Nick
Member #: 154
Midlands
well i'll do the stem seals anyway while its all apart, but would it be worn guides after so few miles?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
How good are the seals in your turbo?
Alex
AlexF
Nick
Member #: 154
Midlands
you tell me....lol
i have no idea but it would be just my luck for that to be on its way out though.
gonna take the head apart anyway and replace the stem seals just because ive got some knocking around and i may aswell while the heads off
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
well theirs more than one way to get oil in the exh on our engines!!
The turbo if leaking pours oil into the exh and burns... so if the heads new it could be an old turbo.
Don't take that to read you need a new turbo... they can smoke for ages!!!
Alex
AlexF
Nick
Member #: 154
Midlands
yeah its an unknown turbo, well it was on when i bought the turbo engine. i've got no intention of changing it until it goes pop or something drastic though *wink* or maybe when i win the lottery.
pete
Member #: 275
bonie scotland
pour engine oil into bores aprox 10mm leave it for a wile ie 24-36hrs, if oil gone problem
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Pete... won't the oil just run round the rings to the gap and then down to the next ring and out?!
alex
AlexF
Doodmeister
Member #: 149
Alberta, Canada
I know i shouldn't but i'm LMAO at that one pete do you mind me asking how many engines you've build or deemed (problem) with your method of elimination ?
SumpNut
Member #: 28
i have used petes method in the past - on rebuilt engines it takes a few days to all go through - if your engine is very worn or has knakered rings it will go through very quikly indeed
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
but you can just stick a feeler blade down the side instead...
or even measure the bore....
The oil method is not really going to tell you anything a compression test wouldn't have done with in the engine in one piece.
Alex
AlexF
Nick
Member #: 154
Midlands
well as it happens i did a comp test not long before we stripped it down. dunno if the gauage was playing silly buggers or what though as it went to 120psi, then to 150, then to about 160. it kept building up as it was cranking over. probably just me and davepugh not using the gauge properly though.
when we comp tested it at karls after it was run in, it was 118-120 across all 4.
Doodmeister
Member #: 149
Alberta, Canada
Wasn't that with a STD head Budd ?
Did you do it wide open throttle like the last time ? and it was a different gauge so could read a little different.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
you need the enigne to spin over untill the needle hits a maximum... about 5-6 times or 10-15 seconds..
As Karl say, remember to hole the throttle open!
Alex
AlexF
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I regulally run redex through my spark plug holes and petrol, does that only keep em clean for a few miles too?
Nick
Member #: 154
Midlands
nah we comp tested it when i came up to your's to take you out for a blast in it after it had been RR'd. the new head went on the day before the RR.
yep wide open on the throttle, all plugs out, tripped out me fuel pump aswell save it going everywhere.
it said on the instructions with the gauge to crank it over for about 10secs, but it just kept building up and didnt seem to show any signs of stopping. it was a gunson hi-gauge we used if thats any help?
just seemed weird to me thats all, as on the other comp testers ive used its just stopped at a certain pressure and not gone any higher.
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
