| Home > Wanted > Metro Turbo Ignition System, Coil, Distributor etc | |||||||
7 Posts Member #: 9394 Junior Member |
30th Mar, 2011 at 05:21:58pm
I need all the bits to run an electronic ignition on my mini. Turns out it has the original mini running gear and only found out today when i went to go get it tuned :(
104 Posts Member #: 8965 Advanced Member MIldenhall, Suffolk |
31st Mar, 2011 at 10:24:17am
I have a new Turbo Distributor. Has the module on the side. You would just need a coil and pigtail to plug it in. £40 plus postage. |
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
31st Mar, 2011 at 06:40:54pm
Hi I've got a micro dynamics ems5 turbo ignition system avonbar & demon tweeks sell them check there sites for details & give me a call if its any good for you 07746127485 |
31st Mar, 2011 at 09:55:49pm
On 31st Mar, 2011 Dark Angel said:
I have a new Turbo Distributor. Has the module on the side. You would just need a coil and pigtail to plug it in. £40 plus postage. What make is it mate? Whats the pigtail? On 31st Mar, 2011 scott the joiner said:
Hi I've got a micro dynamics ems5 turbo ignition system avonbar & demon tweeks sell them check there sites for details & give me a call if its any good for you 07746127485 Ok cool, how much you after for that? Also will i need anything else or is that the distributor and coil etc? Cheers. |
2nd Apr, 2011 at 07:54:33pm
Not sure. Bought it from a company on ebay. The loom that plugs into to module. |
