Home > Wanted > Non verto flywheel (standard)
mini23
Member #: 1296
Milford Haven Pembrokeshire
I'm looking for a standard weight non verto flywheel.
Built an engine with a 286 cam and big valve head but want to smooth it out a bit with a normal weight flywheel.
Already have a grey diaphram and uprated clutch for a non verto flywheel.
with a 286 cam i recommend a ultralight flywheel, because it will massivley help to spin the engine up very quickley and with you fitting a 286 cam the engine doesent have to overcome the short timing figures and lift on tickover.
dont forget to get the whole rotating assembley ballanced!
I have a standard one. It was originally from an Austin 1300 GT (not mini) so had a load of counter balance on it. Fast Carl turned that of for me and it's been used in the van since. Looking for £20 plus post.
mini23
Member #: 1296
The ultra heavy 1300gt one.
I'll go for that, let me know how you want payment?
Paypal?
mini23
Member #: 1296
I see you point.
But then to try to keep the low idle and smooth out the bottom end power, surley a heavy reciprocating mass helps.
This is strictly a road car, already have a racer.
The power remains the same whatever flywheel is fitted.
So have decided to go standard to make it a little easier for normal driving.
philc
Member #: 1346
bromsgrove
i agree with benross, a lighter flywheel with this cam, i think you will find you will notice the cam even more with a heavier flywheel, just my opinion
PMed
