Home > Help Needed / General Tech Chat > Wet subframe to dry with coilovers?
adrian
Member #: 2726
wakefield
Hello.
Just wanting to know if its possible to convert my wet subframe to run coilovers? Im guessing I remove the hydro bits and weld on the bracket to mount the coilovers on.
Regards
Adrian ( currently in sunny spain :) )
nutter driver
Member #: 47
Not very sunny swanage
the subframes wont need modifying at all, the top mount at the front bolts onto the body, with the bottom mount on the top arm. (you may need a dry top arm, not sure if the wet cars had shocks??!!
At the back, again, nothing on the subframe is any different, shock mounting at the top of the wheel arch, (needs reinforcing) and the bottom mount is on the radius arm, (again, you might need dry readius arms possibly....)
eden7842
Member #: 8852
leicestershire
the front top arms can be used with hi-los as it compensates for the different ratios
