| Home > Help Needed / General Tech Chat > GT1749V shaft and compressor wheel in a GT1752 | |||||||
162 Posts Member #: 9342 Advanced Member Southern Norway. |
2nd Apr, 2011 at 11:17:28am
Hi all of you, i was wondering if i could use a shaft and compressor wheel from a GT1749V in a GT1752S?
3rd Apr, 2011 at 12:55:20pm
No one knows? it has a smaller turbine wheel, and compressor wheel, but i could swap out the compressor wheel with one from a gt1752.
3rd Apr, 2011 at 01:05:46pm
Why bother? The Gt1752 is pretty good as it is. On 11th Feb, 2015 robert said:
3rd Apr, 2011 at 01:15:12pm
Agreed, nothing wrong with the GT1752. On 26th Oct, 2004 TurboDave16v said:
3rd Apr, 2011 at 01:52:37pm
well, i bought one of ebay which was supposed to be good, with only minimal play in shaft, but turned out it had huge, so the turbine wheel and shaft was broken, therefore i need a new one. And i found a rebuild kit on ebay for just about 100£ with compressor wheel, all bearings, turbine shaft etc, but this was for the 1749V. That's why i was wondering if i could just swap these out :) |
3rd Apr, 2011 at 02:09:06pm
You cant just swap them, you need the housings to match the compressor and turbine, in which case you may as well just use the whole VNT turbo.
3rd Apr, 2011 at 02:17:29pm
ahh, well in that case, i'll have to rebuild using gt1752 shaft and wheel.
