Home > For Sale > Few bits for sale
Pauly
Member #: 9045
Wolverhampton, West Midlands
Alright chaps.
Just got a few bits for sale, will be taking stuff to Malvern so everything is collect only until after the show when I will sort out postage.
Garret T3 Turbo. Reasonable condition, slight bit of side to side play on the impeller shaft but nothing much and a bit of up and down play which I beleive is nothing to worry about (rebuild?). C/W Metro manifold and (I think) standard 4psi actuator. £90
Audio wiring, used in my old mini cost over £100. Speaker cable/RCA's/mains cable, everything needed to run 2 front components and a rear sub with the amp in the boot. £20
JBL GTO 75.4. 4 channel amp. Forgot the specs but they will be on the net somewhere. £60
Mini SPI Injector. Not sure if its a good one as it came off my sidewalk with cold running issues which later I found out was a lambda switch fault in the ECU, so maybe is a good unit. Temp sensor boss in the manifold has been cross-threaded from the factory! Managed to fit a new one though. £15
Brand new in box. MPI mini wipac quadoptics headlight units (no side light holders, just the headlight unit) I think these are MPI they have white plastic backs. £15 Pair.
Chrome mini sill strips, mint, never fitted brought from somerford mini (bloody expensive). £15
Will put some pics up later today.
Cheers.
Edited by Pauly on 2nd Apr, 2011.
philc
Member #: 1346
bromsgrove
interested in the lights, pics please
almichie
Member #: 2065
I'll take the headlights and audio wiring please...
Shaft seems nice and snug
Ozyris
Member #: 9054
Disneyland Near Paris
can i have a picture of the T3? =)
it's a standart metro one?
Pauly
Member #: 9045
Yep standard metro unit. Forgot it comes with the exhaust elbow also.
