| Home > General Chat > Newbie-Novice alert | |||||||
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
25th Nov, 2003 at 08:57:28pm
Hi |
26th Nov, 2003 at 10:01:40am
hello and welcome!!
AlexF |
195 Posts Member #: 26 Advanced Member Cannock |
26th Nov, 2003 at 01:46:23pm
Might add cheap and strong yes but if your going for something running very high boost then a set of omaga dished pistons will be required as there is only a certain about of material that can be removed from the combustion chambers. And therefore you will need the extra dish of the pistons to get hte compression ratio down.
26th Nov, 2003 at 06:13:43pm
Cheers for the advice guys, my plan was to rebuild the engines internal with the thought of running high boost in the future. So the plan was to spend the money on the internals at the beginning and as i get more confident with the turbo set-up increase boost, add intercooler and other mods in the future, the car is going to be a fair weather/weekend racer, so it doesn't need to be 'nice' to drive day to day. What sort of cam would people recommend??
26th Nov, 2003 at 07:21:53pm
phase 2 turbo cam from avonbar/MED or a mild cam such as an sw5 (not tried that one). These should be reasonable for what you are after. Do not go for the phase 3 cam as this is for the drag strip or race use only |
