| Home > Help Needed / General Tech Chat > Pre verto a+ allegro?? | ||||||
20th Mar, 2005 at 06:50:33pm
Went to scrappy today and found a pre verto clutch assy on a 1275 a+ allegro,is this standerd or has someone put the wrong wok on??
![]() 2641 Posts Member #: 19 Post Whore newcastle |
20th Mar, 2005 at 07:54:43pm
some of the early allegro had them , also they had nice diff ratio in them 4.1 and 3.9 if i remember. Everyone knows that instructions only have to be read if the thing doesn't work....
20th Mar, 2005 at 09:05:30pm
Yes some early allegros definately had 3.9:1 diffs in.
20th Mar, 2005 at 09:15:09pm
Forgot to mention it was an estate-so is it worth having the whole lot out,The engine has loads of bits missing and looks pretty sorry
21st Mar, 2005 at 01:25:25am
Depends what you want from it?? If the engine and box is cheap enough its a good source of 'early' type clutch parts, and the CWP will be worth reasonable money as it is low ratio.
28th Mar, 2005 at 11:05:38pm
Gave up on that one but got a recon pre verto flyweel assy of minifiniti,got the allegro top engine mounts as they look mega beefy and bolt onto head studs
