| Home > Help Needed / General Tech Chat > turbo engine id | |||||||
337 Posts Member #: 9138 Senior Member wolves |
4th Apr, 2011 at 10:40:03pm
done a search but no real answer , apart from engine number is there any other ways to ID a turbo block/gearbox ?. i have been offered an engine and the engine number comes back as a turbo lump . are they worth any more than a std 1275 or should i just consider it as worth the same as a used/worn out 1275 na unit ?
![]() 514 Posts Member #: 5362 Post Whore wexford in ireland |
4th Apr, 2011 at 10:46:48pm
afaik theres a big x on the block, think there fuck all if any difference
On 5th Jan, 2011 wolfie said:
he floated over to mine for a bit of ring |
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
4th Apr, 2011 at 11:32:54pm
they are generaly considered to be worth a bit more especialy if it includes the turbo and the hif44 ect.
Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
5th Apr, 2011 at 04:44:20pm
in short ........ also you need to look on top of the valve stems on the exhausts these are bigger diameter than the inlets they are sodium filled exhaust valves
