| Home > Help Needed / General Tech Chat > EDIS Coil Mount Bracket - Transfer Case mounting | |||||||
![]() 568 Posts Member #: 1200 Post Whore Bristol |
6th Apr, 2011 at 12:57:35pm
Hi all
Edited by pickmeup on 7th Jun, 2011. |
![]() 539 Posts Member #: 6807 Post Whore York |
6th Apr, 2011 at 03:09:17pm
I've not but 10 mins ago done this myself for the same reason. I got 66mm between hole centres and a 1/4" UNC thread. |
6th Apr, 2011 at 03:31:18pm
Agree with the 66mm (presumably actually 2 5/8") but my threads are 5/16" UNC, not 1/4" Schrödinger's cat - so which one am I ??? |
6th Apr, 2011 at 04:47:48pm
cheers guys! will model it up in a mo, i thought they were 5/16" UNC , maybe there is a difference? |
6th Apr, 2011 at 08:16:39pm
Not long put my coil in that place, for some reason mines been tapped out to metric thread, because i tried a 5/16 unc bolt in there which i presumed was correct and it wouldnt go in, then tried an m6 i think and it went in after id run a tap in to get the swarf and rubbish out the threads On 26th Jan, 2012 Tom Fenton said:
6th Apr, 2011 at 08:54:47pm
On 6th Apr, 2011 Rod S said:
Agree with the 66mm (presumably actually 2 5/8") but my threads are 5/16" UNC, not 1/4" Appologies, it is 5/16" UNC |
8th Apr, 2011 at 10:18:57am
This is the first stab at the model, going to try and get it built over the weekend.
Edited by pickmeup on 8th Apr, 2011. |
14th Apr, 2011 at 11:02:08pm
First attempt, hopefully making it on the machine over the weekend, i blew the missus laptop up prior to plugging it into the megajolt earlier so im in the bad books! :(
15th Apr, 2011 at 07:07:14am
which side of the transfer case does it over hang? if it's the engine side it may catch the block.
15th Apr, 2011 at 05:37:39pm
it overhangs the wok cover, i didnt want to make it like the SC one and the way i have pipes from the remote oil cooler to the front of the engine means this was the best option. Its in the machine being built now so hopefully monday i can take photo of the real item Edited by pickmeup on 15th Apr, 2011. |
21st Apr, 2011 at 06:36:33pm
Got the bracket out of the machine and trial fitted it on the engie, the mounting holes need to be taken out about 20thou for clearance but it should work.
![]() 489 Posts Member #: 9159 Senior Member Devon |
21st Apr, 2011 at 07:05:11pm
how much for one more? |
21st Apr, 2011 at 07:12:31pm
Looks good On 11th Feb, 2015 robert said:
![]() 130 Posts Member #: 9395 Advanced Member |
21st Apr, 2011 at 07:41:47pm
On 21st Apr, 2011 jamestar said:
how much for one more? And another Looks really good Polished alloy or stainless would be fantastic |
21st Apr, 2011 at 07:47:55pm
21st Apr, 2011 at 07:56:16pm
will get some quotes for making some up out of something more durable and heat resisant than nylon and let you know!
