Home > Technical Chat > oil pump. whats the difference bar £20
turbominij
Member #: 2104
Essex - UK
whats the difference between these two?
http://www.med-engineering.co.uk/catalogue...pacity-oil-pump
and
http://avonbar.com/prodDets.aspx?pId=207&br=13_113
Edited by turbominij on 6th Apr, 2011.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
Profit?
Rick.SPI
Member #: 8027
I'm not sure but rest assured anything from med will be expensive, although most there stuff is exceptional quality. If these are the same however I can't see a reason to justify the extra price.
PROFIT as said by mr lizard,
its well known and "well proven" that a normall steel backed pump is well up to the job, around £12 from minispares north
hazpalmer
Member #: 9038
Carlisle, Cumbria
yeh and minispares sell a high capacity turbo oil pump, don't know cost though
sx_turbo1
Member #: 4608
"Member"
these pumps are exactly the same except for costs
turbo hogster
Member #: 178
stowmaket suffolk
as ben said the steel backed pumps are very goos and well upto the job, only realy need a high capacity pump if using squirters even then i think the stell backed normal pump ist still big enough
The 'turbo' oil pump is around 25 quid. 9 gall per minute as opposed to 6. I bought one for my build just for the sake of it tbh, even if its overkill it cant do any harm :)
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
