Home > Help Needed / General Tech Chat > wheel stud for specials...?
wagon_rider
Member #: 9241
Edinburgh / Dumfries
Hi -
Please can anybody advise me on the length of stud I should have for Mini special wheels?
Thanks!
Al
wagon_rider
Member #: 9241
Oh - and could anybody suggest a set of security nuts for them? :)
wez
Member #: 9271
Stoke on Trent
iirc the studs are standard length, its the nuts that are specific to the wheel.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
munnracing
Member #: 5193
Dunstable
in regards to wheel nuts if you havent got an original set i would recommend getting a set of mini life wheel nuts and put them in a lathe and machine them down so they fit obviously buy more than you need and make sure that there not to long after i.e the bolt coming through the wheel to much
minirsp
Member #: 2154
Stockton on tees
Try this link original wheel nuts, got some the same as this for mine.
http://cgi.ebay.co.uk/CLASSIC-MINI-SPECIAL...=item1c1ab009ac
Darren
wintersurferuk
Member #: 2208
im stuck with this as well.
Ive had to put small spacers on the back as it was touching the spax shock.
ive ordered two sets of wheel nuts and there both different. i'll try and get some photos of them, but they dont seem to go on much. Im thinking of getting longer studs, then the nuts with holes all the way through,
im going to phone around and see what people are sellings.
wintersurferuk
Member #: 2208
thats one of the sets ive got. but im not the keen on them.
Star Mag
Member #: 375
Leicestershire
Standard length studs. I've got my nuts from Jonspeed. Not cheap but the only place I could get them!
wagon_rider
Member #: 9241
Yeah thinking about it I'm probably going to need 20mm spacers too...
Hmmm......
mini93
Member #: 2017
Warwick.
does anyone know the mini special nut dimensions? shank diameter and shank length? also thread pitch?
i know someone who does nuts but need to make sure i get the right one (and make sure he sells the right ones!)
David.
