Home > Introduce Yourself > G\'day from Australia!
IKNDY
Member #: 9424
Melbourne, Australia
hey all,
just found this forum and i am in the process of building my second mini, this one will be turbo of course!
i'm new to the whole idea of a turbo engine as the first engine i had built (i'm going to use the same engine from my first build) was just a fast road 1330cc (A+) with close to 12:1 compression. i'm still trying to find the spec sheet of parts that were used but i know it has a 12g940 head on it - heavily ported/polished/shaved - is the 12g940 head the way to go on a turbo build? i was thinking i may need to start again with the head as i don't want to use a sandwich plate to lower the compression.
anyways, i'll save the questions for the forums and i'll see ya's around!
Russell
george91
Member #: 8932
Welcome
It will depend on how much has been skimmed off the head as to whether its much good for turbo use, ideally you will need to lower the compression ratio to roughly between 9.5-8:1 depending on what sort of boost pressure your planning to use.
A 12G940 is what most on here are using on 1275 blocks and some 998s with exception of 7/8 ports or 16 valvers.
Anyways, theres more than enough info on here to answer all your questions so have a search around.
Cheers, George.
Edited by george91 on 7th Apr, 2011.
EricsAmerica
Member #: 7891
Annapolis, MD USA
Welcome Russell....head will probably have to go if it's been shaved....need to go in the opposite direction for boost. Lots of great info on here....read lots and search even more....great group of motorheads here with lots of advice to offer... *Yes*
Eric
my pics.... http://www.fototime.com/inv/7AAF37CF3EFA956
Hello and welcome
Fortecphil
Member #: 7641
Jersey, CI
Welcome along mate.
In my best Australian accent (which is pretty poor) "G'day!"
Welcome aboard!
a warm welcome russ........ well its all here for you on turboing and were here to help, loads of great parts for you in the uk
Welcome to TM !!
IKNDY
Member #: 9424
thanks everyone....my eyes have already gone square from sitting in from of my laptop reading through some of the forum!
Hello and welcome to TM,
We have the best search on the net it will be your new best mate.
wng691s clubby
Member #: 9252
Cleethorpes
welcome
Done now needs redoing lol
welcome to TM
