Home > Help Needed / General Tech Chat > next step
minichipper
Member #: 9402
hi this is my new mini ive had it about 3 weeks in that time I've replaced the brake lines, replaced the clutch cylinder seals, quick shift, made the front sub solid, and the rear new bushes, oil filter and oil change, removable bonnet, new arches, alloy sump guard and hilo's. whats next well i'm in the process of buying some 10' wellers,
*what is a good fully adjustable shock for all the way round.
*where's the best place to set the ride height at cause i want to hill climb it and track it at some point.
*best place to buy a full internal roll cage from.
*also where can i buy a full blue silcone pipe set for a 1.3i spi copper.
thank you danny
there is a protech shock group buy in the for sale section which could be worth a look.
george91
Member #: 8932
Protech has a good rep from everything i've heard and like john said theres a group buy on, also go for hilos if you haven't already for adjustable ride height.
As for cages, if you want a cage thats bolt in go for safety devices, there the best for bolt in type and you can buy it in bits.
And minispares is the place to go for silicone hose kits.
Edited by george91 on 7th Apr, 2011.
