Home > Help Needed / General Tech Chat > metal in sump problem found!
NickG
Member #: 7912
Australia oi oi oi!
if you remember i was getting shim like metal in my sump & the box had just been rebuilt.
so i took on everyones advice & pulled it out after i was still getting the same type of metal through my box.
i did not want to chance it anymore, after more of this below!!
bugger :(
Uploaded with ImageShack.us
the problem was on the side plate of the diff cover the shim had collapsed & was pulling bits through the bearing, anyways no damage all fixed & happy days!
so all good problem fixed time to upgrade cam.!
so my little lemon 45atw engine is getting a cam upgrade to a RE83T then the sc12!
should be interesting now.
Edited by NickG on 8th Apr, 2011.
lucky very lucky !!!1
Yep, might have caused some shoes there mate
well at least it is all settled
