1975 Surf Blue Track/Hillclimb prepared Mini
Interior spec:
2x Cobra Monaco Bucket Seats
1X TRS 4 point Harness
1X Sparco 4 point harness
Safety Devices 16 Point roll cage
Electric Isolation
Fire extinguisher Plumbing
Brake/Fuel/Electrics run internally
Brake Bias valve
Ally Switch Panel
Oil Pressure guage
Exterior Spec
Curley Fiberglass/kevlar removable front end (2 piece)
Curley Carbon Fibre boot floor
Fibreglass Bootlid
10x6 Mamba alloy wheels
Surf Blue body with black roof
Miglia Weber Box
Cooper S front brakes
Engine/Performance spec/modifications:
The engine has only done around 150 miles so is still being run in.
1330 A+ Engine - Built by retroracer1380 on the forum
Mini Sport Stage 4 Head
Lightened/Balanced fly/crank
Weber 45 on a 6" Alloy Manifold
Straight Cut drop gears
X-Pin diff
649 Cam
Maniflow LCB and full exhaust system
20 Litre Alloy Fuel tank and Swirl pot to eliminate fuel surge.
Twin facet fuel pumps + filter king regulator
External Electric Isolation
External Extinguisher Pull
Gaz Adjustable Shock Absorbers
Genuine High lows
Fully adjustable camber front and back
Adjustable rose jointed bottom arms
Adjustable Heavy duty Tie Bars
Brake Bias Valve
Tubbed Wheelarches
As you can tell from the spec it is a very well sorted car for use on both the track and the road, i will be sad to see it go but it just doesn't get the use it deserves, you will not be dissapointed! The engine pulls extremely well and is very torquey and revvy. I'm sure whoever buys this car will have endless amounts of fun!
The car is located in worcestershire - i am looking for around £5250 however i'd accept offers for a quick sale!
