Home > Technical Chat > IC air temp
I have been thinking today how hot do you think the air will been when it has passed through the IC. Like can i put the air filter behind it if you see what i mean.
thanks simon.
scott the joiner
Member #: 9229
newcastle upon tyne
I get what you mean that's actually where mine is not intentional just the way it all went together
Ben H
Member #: 184
Melton Mowbray, Pie Country
Well behind the intercooler will be warmer than the ambient, under boost condition. It will work, putting the air filter there, but if you can get fresh air that would be better.
http://www.twin-turbo.co.uk
turbominivanman
Member #: 1504
Westbury, Wiltshire
I'm with Ben on this.
I have a sensor behind my intercooler connected to a gauge on the dash which tells me what the air exiting behind the intercooler is getting up to. I'd rather it wad in the intercooler on the output side but that's not necessary as I can read off the plenum inlet temp from the intercooler directly off Megasquirt.
On a 15 deg C day, the air temp behind the intercooler goes between 25 and 35 deg C. I wouldn't want to be sucking this into the air filter. It's a never ending spiral. The hotter the air going into the compressor, the hotter it'll be going through the intercooler and engine.
Best to sight the air filter in a sheltered area behind the grill but not in direct cold air stream. If not possible, duct a cold air feed to the filter.
Richard.
Richard.
O right, looks like i will have to duct some air to it then.
thanks so far
Simon.
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
