| Home > Wanted > Turbo oil bits | |||||||
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
13th Apr, 2011 at 11:40:26pm
Anyone got the turbo oil feed and return bits laying around?
Turbo parts collector at the moment, almost ready. |
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
14th Apr, 2011 at 07:27:03am
I would get a. Braided oil feed the std ones brake to easily |
14th Apr, 2011 at 07:32:31am
We have a braided oil feed from the van's T3. That might be for sale - need to talk to John first, but will PM you if it is On 11th Feb, 2015 robert said:
14th Apr, 2011 at 03:57:57pm
Cheers mate. The return bit's waaaaaaay to expensive. I might make the return bit for the block. £20 for a tiny bit of pipe and plate, and £14 for the 90 degree elbow, seems too much to me. Turbo parts collector at the moment, almost ready. |
14th Apr, 2011 at 04:56:04pm
Which bits do you need then? If something is worth doing, it's worth doing half of. |
15th Apr, 2011 at 09:33:21pm
All I have is the aluminium 90 degree return bit that sits on the turbo. I need:
15th Apr, 2011 at 09:44:04pm
I would not complain about spending £34 if your serious about charging your car you will be spending a fair bit more than that
15th Apr, 2011 at 10:45:21pm
This is the last bits I need to fit the turbo, and open up the chamber in the head. But I need the oil feed aswell, and they're £50 plus on minispares. So
16th Apr, 2011 at 05:36:44am
My feed line cost me £20 at the local hydraulic hose supplier.(In braided steel, too) |
17th Apr, 2011 at 09:07:59pm
Got oil line and return hose. Just need the return plate that bolts to the block please. Turbo parts collector at the moment, almost ready. |
