| Home > General Chat > Help needed with Golf mk4! | |||||||
162 Posts Member #: 9342 Advanced Member Southern Norway. |
14th Apr, 2011 at 01:49:23pm
G'day all, i'm having some problems with my golf, and thought i'll ask here, as you guys seems to know a bit about engines! :)
14th Apr, 2011 at 01:51:51pm
Coolant temp sensor? If something is worth doing, it's worth doing half of. |
14th Apr, 2011 at 01:54:14pm
Hmm, i was actually thinking of the same, it seems like my local VW workshop is unable to figure it out, nothing shows up on the vag com. if its not the coolant temp, what else could it be? |
14th Apr, 2011 at 02:09:05pm
I will try changing it,
14th Apr, 2011 at 02:12:57pm
It was only a guess. Don't take it as gospel. If something is worth doing, it's worth doing half of. |
181 Posts Member #: 9072 Advanced Member Jersey, Channel Islands |
14th Apr, 2011 at 03:03:33pm
I use to work for VW as a mechanic and the 2 most common faults are coolant temp sensor (green 4 pin that is hald in with a plastic clip) and the MAF.
Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya! |
14th Apr, 2011 at 03:20:33pm
Thx fasteddie, will check it out! Should i clean the MAF with a special solvent or? |
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
14th Apr, 2011 at 03:38:06pm
hey,
14th Apr, 2011 at 03:42:54pm
Hmm, i'm not sure actually, i don't think they ever been changed. Will have this in mind though! |
14th Apr, 2011 at 05:04:08pm
Good point Martin.
15th Apr, 2011 at 12:03:50pm
Hmm it wasnt the coolant sensor. and the maf seems to be fine. Tried unplugging. Still have the same problem |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
16th Apr, 2011 at 08:27:41am
What engine code is it? when was the cambelt (waterpump) done? |
56 Posts Member #: 5200 Advanced Member Bath, Somerset |
19th Apr, 2011 at 11:48:45am
Does it have a crank sensor? They often fail on VWs. |
19th Apr, 2011 at 11:55:18am
Yes i think it has.
19th Apr, 2011 at 11:16:40pm
At least you got one of the good engines, have you had it code read? |
20th Apr, 2011 at 09:43:49am
I had it Vag com'ed half a year ago, but not recently no. It didnt come up with any codes at that time. =/ |
26th Apr, 2011 at 07:22:12pm
I had it code read today by an mechanic, and he couldn't find any errors on it.
26th Apr, 2011 at 07:42:49pm
if there are no codes, and truely no signs of the problem on live data (requires someone who knows there onions, not just some monkey with a scanner/vagcom) then the only thing that would cause this IMHO, is a fuel pump, fuel pump replay, fuel filter.. well, you get the idea :) fuel delivery issue. Edited by evolotion on 26th Apr, 2011. turbo 16v k-series 11.9@118.9 :)
4th Jul, 2011 at 06:28:48pm
Hmm, still having this problems, throttle body cleaned, spark plugs changed, ht leads changed. But problem still persists, i'm running out of money now, lol :)
Edited by Utking on 4th Jul, 2011. |
