| Home > General Chat > air compressor tank - oil!! :( | |||||||
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
15th Apr, 2011 at 05:19:25pm
Hey all,
15th Apr, 2011 at 05:23:41pm
are you painting with it or just using tools? |
15th Apr, 2011 at 05:26:12pm
i was wanting to paint with it but only if i can sort it i guess!! |
15th Apr, 2011 at 05:31:27pm
Never done this before, but personally, id pour some panel wipe or similar liquid that cuts through oil into the tank, swill it about and drain, and leave the drain plug open for 48 hours to let the vapour escape On 26th Jan, 2012 Tom Fenton said:
15th Apr, 2011 at 05:37:33pm
'd say as above but you may need a couple of goes to get it all out, I'd also do a water flush after. On 28th Aug, 2011 Kean said:
15th Apr, 2011 at 06:08:04pm
thanks for the replies!!
15th Apr, 2011 at 06:12:26pm
http://www.frost.co.uk/item_Detail.asp?productID=8680
15th Apr, 2011 at 06:32:45pm
water is ok in there as long as it dosent sit, you always get a bit of moisure, thats why you have a water seperator On 28th Aug, 2011 Kean said:
150 Posts Member #: 8909 Advanced Member North Cornwall |
15th Apr, 2011 at 06:34:08pm
Air has water in it, hence a water drain in the tank, you'd be fine to flush it with water and the leave the tank open to dry.
On 15th Apr, 2011 martpaul said:
thanks for the replies!! The only thing about the water flush is im nervous it rots the tank and flakes get into the system!! If in doubt... flat out! The words of a true legend |
15th Apr, 2011 at 06:58:47pm
cool cheers guys,
133 Posts Member #: 9277 Advanced Member Nottingham |
15th Apr, 2011 at 07:21:33pm
I get about 250ml of water colllected in mine every time I use it for a few hours! |
16 Posts Member #: 9188 Member Brighton |
15th Apr, 2011 at 07:30:07pm
i worked for a guy servicing compressors for a while he used to jet wash them out to clean them.
