Home > Help Needed / General Tech Chat > play in turbo shaft.
Gaball
Member #: 7169
Gobshite that posts wank videos.
Somerset, UK
Just got a GT1752 off eBay and I wanted to know how much play is to much and in what direction.
There is a 1 or 2mm play up and down. Left to right there is a slight amount of minimal play? It spins freely.
Gaball said:
Motorsport Engineering Student
Project Car 1293 Turbo Mini (on a student budget)
On 7th Oct, 2010 apbellamy said:
Carbon but plug?
Sounds too much to me.
Whip off the compressor housing and check to see if the compressor wheel has touched it.
turbominij
Member #: 2104
Essex - UK
In and out play is more of a problem if the turbo is dry you will always have up down left and right play try putting some oil in it and try again.
"Tuning should be a compromise between what is possible and what is necessary"
10)Thou shalt always quest for more power
