Home > Help Needed / General Tech Chat > clutch issue
eden7842
Member #: 8852
leicestershire
hey
ive got this problem with my clutch and just want to know why this can happen with no solution?
and when it happens is the best way to fix it is to extend the rod?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=342769
We had the arm bent on our to bring it closer to the WOK.
Best to check that there is no play in any of the parts and the plunger and arm (especially the ball on the end) are not worn.
yep wear is a bugger on these,
1mm wear at the ball is about 5 at the slave cyl, the ball can easy wear 1mm, as can the thing it contacts, and the clevis pin, and its hole, that all equates to about 20mm at the slave pin.
change the arm and clevis pins firstley!
the pressure plate may have lost its spring especially if it has been on some time. dont go down the route of extending the slave cylinder arm or you will be in a world of hurt. please correct the above i have mentioned
eden7842
Member #: 8852
leicestershire
il inspeck the arm then, the plunger and diaprham is new
