| Home > Beginners Tech > Gearbox / Diff casing | |||||||
12 Posts Member #: 9410 Member |
18th Apr, 2011 at 11:32:01am
Am I correct in thinking the gearbox casing and diff casing are matched together?
18th Apr, 2011 at 11:35:36am
They are machined as one. Not generally a good idea to mix and match them up. If something is worth doing, it's worth doing half of. |
18th Apr, 2011 at 11:36:20am
you are correct, they are machined as a pair.
18th Apr, 2011 at 12:59:10pm
18th Apr, 2011 at 04:30:12pm
It's a pretty big crack and I'm no good with a welder
18th Apr, 2011 at 04:32:11pm
take it to someone who is good with the tig and they may be able to repair it. If something is worth doing, it's worth doing half of. |
18th Apr, 2011 at 05:32:33pm
Will it bolt up to the other half of the case properly though? On 11th Feb, 2015 robert said:
18th Apr, 2011 at 05:37:24pm
That could be welded, the way to do it once it was as clean as possible and a prep ground into the crack would be to bolt it hard up to the rest of the gearbox, and then weld it.
18th Apr, 2011 at 08:05:16pm
Yer it bolts up to the gearbox with no problem. I have to get the gearbox and diff rebuilt so will ask around and see if I can get it welded with the rebuild. |
18th Apr, 2011 at 08:23:56pm
If you get that good and clean you will be able to ally solder it with that techno weld stuff and a big blow torch,
45 Posts Member #: 2544 Member Biddulph, Stoke on Trent |
10th Aug, 2011 at 08:37:21am
On 18th Apr, 2011 Joe C said:
If you get that good and clean you will be able to ally solder it with that techno weld stuff and a big blow torch, I did a sump on an astra GTE and it worked a treat, just pre heat in the oven on full, then blast it with the torch and get the solder in there. sorry Guys bit late with this, just seen it. I think its called HTS 2000, Frost's sell it. looks good, they do a vid on the web couldn't destroy a tube and plate joint (ala inlet manifold?) even with a hammer. Hmm, wonder it thats a poss for some ally TB's It's not the age that makes me creak it's the mileage |
